- Sep 16, 2003
- 12212
- 12,221
I just noticed two real stupid design flaws as i was awlking down the dock...
first, here is that nice looking Azimuth 62, where the owners had to put a rag on the stern line to prevent it from rubbing on the gel coat ! seems like the designers at Azimuth recessed the stylish stern clear so much that when you cross the stern lines, they will rub on the gelcoat ! so here we have a 2 to 3 M dollars boat where you need to put a rag on the lines... nice...
second, a few slips down was a good looking farily new Symbol, about 45/50'. Traditional looking trawler/tug inspired design. one big problem though... near the bow, the fiberglass and railing extends beyond the rub rail ! so if you need to pivot off a piling... you're out of luck ! sure enough, the fiberglass already has a few chips...
what are these builders thinking? that owners will not tie their boats stern to? that's even more funny since european boats always come rigged for med mooring wigh built in passerelles... and if' you're going to buy a tug styled trawler, chances are you will be doing some extensive cruising and you will need to pivot off a piling once in a while..
stupid stupid stupid. Here is your sign !
