what combination would u start with
dalehollow
I have just purchased my first houseboat, it has 2 solar panels on the roof, I dont know any more than that about them anyway as I understand it they charge my bank of 3 battries, all of which are ready to be replaced, Im sure the seller removed some battries b4 i inspected under the hull, to the question: to run my in cabin lights & possibly a box fan, tv with dvd player overnight away from the dock, what would you recommend i replace these battries with I have heard talk of 6 volt battires, anyway how would you go,
How old are the batteries and what size are they.
What about the boat and other electrical needs as in...starting engines.
Give us more to work with.
Yep. We need more specifics. The solar panel type, rating and age is important too. Power production can fall off in older photovoltaics.
6v golf car batteries are hard to beat. They're tough, relatively inexpensive and light enough to handle yourself. You have to install them in pairs, each pair connected in series to get 12 volts. You can connect as many pairs as you like in parallel. They're not designed as starting batteries but they will probably do the job.
If I recall you said somewhere else your fridge was propane. Electric fridges can be battery-killers and must be planned for. As an absolute minimum you'd need two 6v batteries, and if you're only away from the dock overnight and not running a fridge they should do the job. Otherwise I'd say at least 4.
You have to figure out what your actual power consumption between charges is. A 12watt light bulb draws 1 amp on 12 volts, 60 watts 5 amps, etc. My portable DVD player draws 10 watts (about 1 amp), a regular DVD player and a TV will draw more. A 20" box fan on high can draw 200 watts or 17 amps converted to 12v. Then estimate how many hours you'll be using each accessory. amps x hours = amp hours. Add 10% to anything running off an inverter. Add up all the accessories and you should have a rough guess re your consumption. A more accurate approach would be to install an amp-hour meter or a battery monitor, but they're pricey.
Two golf batteries will give you about 220 amp hours; to avoid damage most folks say don't use more than half that, so figure you have 110 amp hours available. If your consumption comes to much more than that you need TWO sets of batteries. If in doubt add another set.
Solar panels don't work at night so on an overnight trip they're not much concern. However BIG panels can make a big difference in how much battery you actually need over a long weekend. Find out what you can about them.
All this is for the "house" load. Your engine starting load requires a SEPARATE battery; what size depends on the engines. You also need some way of isolating your "house" batteries from your "starting" so regardless of what happens to the house bank you can still get started. I think the common approach these days is a "battery combiner" which will "combine" the batteries when charging but will "isolate" them when not charging. At the very least you'll need a manual off-1-both-2 switch.
Check out this link: http://www.boatfix.com/how/Ele2.html One of the diagrams should somewhat resemble what you have and should help you understand what you're trying to do.
Get back with us with more detail and we can be of more help.
