What do the beeps mean?
NORMinCONN
I have a friend with a 2004 SeaRay 22'. It has a 5.7 with a Bravo outdrive. Yesterday he was cruising down the river the he heard 2 beeps then a 2 minute pause then 2 beeps again. When he put it in neutral, it ran rough. He got it to go again but then same thing. This time when he shifter it in neutral it stalled and would not let him start it with the shifter in the lock (center) position. When he shifter it in the neutral position (button press in, not on gear) it will start until return to center position. Would any one know what the beeps mean? The book says they are stored in ECM's memory and it has to be read with a diagnostic tool. Thanks for your help on this.
There is something along the lines of 25 different faults that could result in the 2 beeps/minute. You need the diagnostic tool to read the fault to tell you exactly what it is.
Yes, you need the diagnostic computer/tool to check the codes. That said, the short beeps and the failure to start probably indicates a bad IAC valve, a common problem, easily fixed. But, don't just throw money and parts at the problem; have a diagnostic run. Hy
Originally posted by Harlan
Probably IAC valve.
+1 on the IAC (Idle Air Control valve). Just had mine replaced on my starboard MerCruiser 6.2L engine. I had the same two beeps, about every minute or so. The marina determined the fault with the diagnostic tool.
Greg
I carry a spare IAC, this problem is not rare. They are easy to change in the wild. Probably need to get a mechanic to put the computer on the new on to make sure everything is in tune and to knock out the old code.
He took it to a Marina to have tested. I will let you know the out come. Thanks for your help.
<< Uh oh. It's beeping. Only 5 seconds to cut the red wire. NO. The blue wire. I think. Maybe. Was it the green w/ black stripe... >>
Yellow wire, yellow wire!
Here a some of the trips for 2 beep Merc fault warning alerts, but note these are apparently 2 beeps/ 1 min. & you'd need diagnostic scanning to narrow down the possiblities:
(1) Cam Sensor Yes 2 Bp/min 90% Open or short, engine must be cranking to set this fault code.
(2) ECT CKT HI Yes 2 Bp/min 90% Open
(3) ECT CKT LO Yes 2 Bp/min 90% Short
(4) ECT Coolant Overheat Yes Constant 6-100 % Engine guardian overheat condition
(5) EST 1-8 Open Yes 2 Bp/min NA Coil harness wire open
(6) EST 1-8 Short Yes 2 Bp/min NA Coil harness wire short
(7) Fuel Injector 1-8 Open Yes 2 Bp/min NA Fuel injector wire open.
(8) Fuel Injector 1-8 Short Yes 2 Bp/min NA Fuel injector wire short
(9) IAC Output Yes 2 Bp/min 90% Only with rpm
(10) Knock Sensor 1 Yes 2 Bp/min 90% Alarm sounds for 20 seconds in NEUTRAL and indefinitely in gear.
(11) Knock Sensor 2 Yes 2 Bp/min 90% Alarm sounds for 20 seconds in NEUTRAL and indefinitely in gear.
(12) Low Drive Lube Strategy Yes Steady Bp 0-100% Low oil in sterndrive.
(13) Low Oil Pressure Strategy Yes Constant 0-100% Low oil pressure strategy.
(14) MAP Sensor 1 Input High No 2 Bp/min 90% Short, no visual on SC1000.
(15) MAP Sensor 1 Input Low No 2 Bp/min 90% Open, no visual on SC1000.
(16) MAT Sensor Yes 2 Bp/min 90% Open or short in MAT circuit.
(17) Oil PSI CKT Hi Yes 2 Bp/min 90% Short, defaults to 51.7 psi.
(18) Oil PSI CKT Lo Yes 2 Bp/min 90% Open, zero oil pressure.
(19) Overspeed Yes Constant RPM Limit Engine over rpm limit
(20) Port EMCT CKT Hi Yes 2 Bp/min 90% Open, defaults to 32 degrees F.
(21) Port EMCT CKT Lo Yes 2 Bp/min 90% Short, defaults to 32 degrees F.
(22) Port EMCT CKT Overheat Yes Constant 6-100% Overheat condition, 212
degreesF(100 degrees C) limit.
(23) Sea Pump PSI Lo Yes Constant 6-100% Low water pressure strategy, defaults to 43.4 psi.
(24) Sea Pump CKT Hi Yes 2 Bp/min 90% Open.
(25)Sea Pump CKT Lo Yes 2 Bp/min 90% Short.
(26) STB EMCT CKT Hi Yes 2 Bp/min 90% Open, defaults to 32 degrees F.
(27) STB EMCT CKT Lo Yes 2 Bp/min 90% Short, defaults to 32 degrees F.
(28) STB EMCT CKT Overheat Yes Constant 6-100% Overheat condition, 212 degrees (100 degrees C) limit.
(29) Steer CKT Hi Yes No No Open and short.
(30) TPS1 CKT Hi Yes 2 Bp/min 90% Short, signal to 5v+, engine will not start. Refer to data monitor screen.
(31) TPS1 CKT Lo Yes 2 Bp/min 90% Open.
(32) TPS 1 Range Hi Yes 2 Bp/min 90% Above 4.8v, 994 counts.
(33) TPS 1 Range Lo Yes 2 Bp/min 90% Below 0.5v, 35 counts.
(34) Trim CKT Hi Yes No No Short, high range, visual warning on SC1000 only.
(35) Trim CKT Lo Yes No No Open, low range, visual warning on SC1000 only.
(36) 5 VDC PWR Low Yes 2 Bp/min varies Short any 5v+ to ground.
