What is the difference Between LOA vs
Mark D
What is the difference Between "LOA" vs "Centerline Length"?
LOA is the measurement of the boat from the front of the bow pulpit to the end of the swim platform. Centerline is an imaginary line down the center of the boat from bow to stern. Perhaps you are looking for LWL, or the length of the boat at the waterline.
LWL is the length of a boat from a navel archietect's perspective. LOA is the length from a marketing executive's perpective.
How do then calculate the "LWL" from just centerline length or any other measurement?
Existing boat you own or one you are looking at to buy? if it existing, you can measure it by looking at the slime line on the bottom. If it is one you are looking to buy, somebody here probably has it or has in the past and already knows the answer. It can be done to within inches with a diagram and some geometry, but let's not expend the effort and embarrassment of having to admit that we would have to use this crap some day until absolutely necessary.
For length waterline, you drop perpendiculars from the the point where the water is on bow of the boat--and the stern of the boat--the "Scum line" works fine. This assumes that the boat is on a trailer or lift.
LWL determines the interior space. LOA determines how much the maker and dockmaster can charge you.
