What is this part called?
Mike Wood
The part that attaches the prop shaft to the transmission on IB's. I always called it a coupler.
Thanks, I've try doing a search on this part with boatfix and others and nothing. Thought i must be useing the wrong name.
Rell Antsy has it...the shaft coupling.
It has been known as a lot of different things..especially when you can't remove it when you have to pull the shaft.
Coupling or flange, which is actually on the coupling.
Originally posted by stmbtwle
I always thought it was a comosellama!
or as Capt.Art says....
at least that's what I always called it.
I thought it was an Illudium Q45 Explosive Space Modulator?
Thanks to all, i needed a few laughs after messing with the Da... things.
