What polisher / buffer do you recommend ?
Chesagansett
Well-known member
I had an old polisher / buffer that wore out. It was never very strong.
What do you recommend? And what's the difference between a polisher and a buffer? Whatever it's called is, it's one of those spinning thingies to take the wax off. Yup, "spinning thingy" is a technical term.
Thanks!
Glenn
I've used the same Black and Decker for 30 years and it is still going strong. I use a wool pad and set the rpms at 1500 to avoid burning the gel coat. Makita makes a very similar machine for around $300. Others will no doubt have a cheaper suggestion, but I'm of the school that believes you get what you pay for.
Glenn,
Not sure if it's applicable to your boat, but if you have a lot of surface area, or simply want professional results - the polisher I bought recently would be tough to beat.
Makita 9227CX3
Got it from Amazon for 180. w/free shipping (price has since gone up a bit). It included a HD carrying bag and two bonnets - a wool polishing bonnet for compounding/general purpose use and a finer wool bonnet for wax buffing. In addition, I bought the sanding kit for redoing my bottom.
I completed the topsides four weekends ago, and was subsequently launched early last week. What an incredible job it did - compared to my old orbital POS.
Although you can get a polish/cleaner paste combined with wax (3M) - polish is actually applied first, then buffed. A good wax should then be applied for added protection and brilliant shine. If the hull is oxidized, first apply a medium to HD compound, followed by polish and wax.
I've got before and after pics somewhere - I can post later, if you'd like to see the results.
Steve
Makita
Only I have an old wood fishboat conversion. So I use the thing to sand. I have actualy stripped the boat ( all 39 feet ) with it. Actualy I have stripped several boats with it.
They are realy tough. But can be a bit heavy after a few hours.
I have a porter cable and have been extremely happy with its performance.
I use my 'money is no object' Festool.
I have it for woodworking, but makes a fantastic buffer.
I have used 'elcheapo 2 speeds from Sears for a long time. $50 bucks today and hard to kill them.
Dewalt has a setup almost the same as the Makita. I think it's about the same price. If you want to go with a variable speed buffer they're both pretty nice. Some people recommend the random orbit models instead, to avoid damaging the gel coat.
Thanks all,
Looks like some heavy duty stuff. My last one was something like $35, and I got what I paid for. The thing I found most annoying, and I imagine it happens with the good ones, too, is that the bonnet quickly fills/clogs with dried wax when I take off the wax. I had to buy several bonnets just to do a 25 foot boat. Unless I was willing to wash and dry it several times in the middle of the job, I needed about 6 or 7 bonnets to remove the wax. I threw them all in the wash, and dried them before the second coat of wax the next day. That was 2 years ago. Last year, I just wiped the wax off by hand with terry cloths. It took about the same amount of time as the polishing machine, as I didn't have to keep changing the bonnet. I bought a bag of terry cloths for the hand wax removal last year.
I'm willing to give the machine polsher another go. What have you all experienced in regard to the bonnets clogging up on the wax removal?
By the way, I don't need the compound step, as the gelcoat is in decent shape (2003 boat).
Thanks!
IMO the bonnets are independent of the buffer. Are you “spurring” the pad???
Those $35 buffers are fine for me. All plastic is usually lighter too. Just look at the speeds and the amp ratings if they are similar to the expensive machines then there is little difference at least for occasional use.
you hold a stick against the pad while running. It spins off the caked stuff.
For years I used either a screwdriver or one of the West epoxy mixing sticks. This year I broke down & spent the 7 bucks for a "spur" from an autobody supplier. Using the real thing is MUCH better.
I also reccomend the Makita. I have the DeWalt & the weight does get to you. You could also buy the $49 cheapie from Harbor Freight when it is on sale for $24.95. That's about 60% of the time.
Al
This is the one I have, paid $29 for it and used it for 2 years with no issues.
In addition to spurring the bonnet I apply the wax with a clean white towell over a 3 x 5 foot area and rub the wax out to a thin film that is easy to wipe off with a clean towell. The build up helps to wax the hull. Some people put the wax on the bonnet but I've found this cruds things up pretty quickly. The wool pads can be washed in the washer at home with hot water and detergent. Do this with your dirty boat cleaning clothes.
Should one look at an orbital or just be careful with the regular rotation models?
I'm concerned about swirl marks, as well as burns.
If you ever intend to use it for compounding, then the orbitals don't have the "oomph" (technical term) to break down the compound. That requires the friction from the spinning pad.
Al
I bought the one Jason posted the picture of above. It was from Harbor Freight and for $29 I figured I did not have a lot to use. I do not use a buffer that often so saw no need to spend any more. It has worked fine to date. I also have an orbital but on fiberglass it takes too long. I have also found on boats not in too bad a shape that mixing a little baby oil in 3m Finesse makes life easier, does a great job and the bonnets go longer between spurring.
