Originally posted by Al_Prisco
Bill, In regard to the fluid samples: It does not matter if you don't have past history. When i pull fluids on a pre-purchase inspection after running the vessel under load, what my main concerns are is if the table of elements reflect excessive wear to a component or contamination from either fuel,coolant or seawater. Also if the vessel has been sitting for any long period of time,corrosion can develop in the cylinder walls creating excessive wear.
So what good are the samples if the fluids were just changed before the samples were taken? Or if the boat has sat unused and there for the oil as few if any run hours on it? And a good fluid analysis company is going to want to know the run history of the fluid and if the sample is of only one brand of fluid or a mix. Because what the fluid is composed of varies from brand to brand.
Most samples will show some contamination. But you have no way of knowing what is normal without the fluids history.
If the engine has any issues that might be leading towards a catastrophic failure you should see evidence of that on a good mechanical survey and proper test ride.
If you do spend the money for a fluid analysis at least make sure who ever does it at least does it right by taking the sample from the right point on the engine and that they do. It cross contaminate the samples.
Be sure that when the mechanic does the engine surveys he/she runs the boat in its normal configuration. Meaning don't let him run it with the engine room hatches open when doing tests and high speed runs. Also make sure you run those engines for at least 10 min. at max RPM. If the owner or broker is reluctant to let that happen be wary of what they maybe trying to hide.
