When to Replace Canvas (Sunbrella) ?
JoeTallyHo
My canvas is in its 11th season on the Chesapeake Bay. The last 4 years, mildew has been growing on the underside due to rain weeping through from the top. It is now part of spring commissioning to thoroughly clean the canvas and put up to 4 coats of 303 Waterproofing on top and 2 coats on the underside. While the water beads on top, a heavy rain will eventually soak through the underside.
When the mildew is cleaned I have been using Spray Nine because it claims it slows mildew growth. I suspect that is also removing the 303, eroding the protection.
I also notice that when I spray 303 on my canvas on my lawn, I still need to add 2 more coats when it is stretched tightly across the frame. This makes sense because the cloth knitting spaces open up a tiny bit, but enough to allow rain to easily seep through. But, have the threads worn away?
The question is this a normal trend of Sunbrella degradation? And do I need to replace the canvas?
I have had my Sunbrella for 9 years. I have never sprayed it with any coating. Once a year I take down soak it in a big tub with mild detergent and bleach.
I let it soak for about two hours and then scrub it with a gentle deck brush on both sides and then hang it over dock railing and rinse it very well. I let the sunshine dry it out and replace it.
The boat is in a covered slip in GA. That helps. It does get mildew from the dirt. Once the dirt is gone it stay like new and looks good.
Joe, I bet you are not killing all the mildew spores when you clean the canvas. Also, I think you should clean it at season's end before everything gets stored for the winter. Maybe put on the protectant during spring commissioning........
Your canvas will need replacing when it begins to be frayed or tears. Or sooner if you don't mind spending that kind of money!
Go onto the Sunbrella website for lots of very good info about cleaning and maintaining your canvas.
You can always paint it! Use latex exterior house paint, mildew resistant (and the cheapest you can find), and roll it on the upper surface. I've gotten an extra 2 years (so far) of use and it still looks great. Most people don't even know its painted and it doesn't leak or mildew, and much more resistant to staining.
Note here....It takes about 1 gallon of paint to do about 100 sq feet.
Peleka, good to see you posting again. I have wondered where your travels have led you and how you were doing. An update would be very interesting to most of the ROs
We also had mold problems on the underside of our Sunbrella.
My wife tried a solution of bleach and water (1 part bleach to 10 parts water) last season and it removed the mold.
The Sunbrella was not cleaned over it's winter storage in our basement.
I waterproofed the canvas this Spring thinking that it would stop the mold but it did not. My wife tried the bleach and water spray again.
We are now seeing threads at stress areas of the Sunbrella breaking away.
We will have all the threads reinforced over the winter but wonder if using the bleach/water is causing the problem.
Lastly, when I waterproofed the top I used the Starbrite waterproofing ( http://www.amazon.com/Star-Brite-Starbrite®-Waterproofing-Treatment/dp/B003CYTOAI ) but only treated the cover with a single heavy application. Should the underside of the cover also be waterproofed when the topside application dries AND is more than one topside application recommended?
TIA!
Ditto
How about some Pic's of where in the world is Peleka?
Seems like a rather broad range of experiences. I have done the bleaching method as recommended on Sunbrella website, but usually in the spring. For winter, I just use the 303 cleaner. I'll try it post season this time.
No rips yet, but on a clear sunny day, I can see sunlight coming through the top. I thought the cloth threads were getting thinner, like an old cotton undershirt would. Not sure if it is my imagination or not, but after 4 coats, I'd swear the amount of light diminished.
Just wanted to see what experiences everyone had before I consider replacing it.
Thanks for all the comments.
Paul,
303 Protectant directions recommend 2 light coatings vs one heavy one. It is also petroleum-based like the Starbrite product. And letting it cure a few hours between coats.
Joe
I've posted pics in the sailboat forum...you know the forum for boats with the telephone pole thing sticking up out of their boat!
I've posted for Tuvalu and also Kiribati. Sorry did not mean to hijack this topic.
Often, the stitching will go bad before the canvas fabric. A canvas shop can often extend the life of your canvas products by restitching with UV resistant thread.
If you have or buy a heavy duty sewing machine and have some basic sewing knowledge, you can do this yourself.
If you store your boat or canvas for the winter, clean it up before storage, don't let it sit over the winter with dirt, mold and mildew.
I don't think "spraying" is enough once the mold has become apparent. Take the canvas down and scrub it with the solution really really well! Then rinse it over and over again. Then rinse it some more! Thoroughly dry the canvas prior to storing it. If you can reinstall on the boat to dry it, that would be the best.
Always store canvas clean in the fall/winter.
