Where to mount flag?
MichaelNJ
I can't find a perfect place to mount a 36" American flag on my boat.
It's a Meridian 341 Sedan Bridge
http://media.channelblade.com/boat_...re/company17802/78057_p_t_640x480_image02.jpg
My boat has radar so I don;t have that kind of all around light. I have the light coming up behind the radar but that part is too short for a 24" high flag.
Ideally, I'd like to have it on an angle off the very aft part of the bridge. Two problems with that are that horizontal part of the esge is narrow, and the vertical edge is much to narrow for anything. The other problem with the top part of it is that it would be inside the canvas enclosure. There is a zipper up the center so I could unzip up from the bottom about a foot and have the flag staff come out. The problem with that is that the canvas will flap around too much in the wind if it is unzipped.
The other place I was thinking in on the transom which is where I had it on my other boat. In this case it would have to go to the left of the transom compartment. So it wouldn't be centered. It also interferes with the swim platform somewhat. At least I board from the starboard quarter and the transom door is there too so you don't have to walk past the flag.
I think the radar arch is too high and also not easy to get to in order to take it down.
It definitely has to go on the stern. I have a yacht club burgee on the bow rail.
I also need to mount a Coast Guard Auxiliary flag. That may go on my antenna.
Typically off the stern or in a rocket launcher pole holder, if you have one. I've seen some on bow rails, but with the constant sea spray, they must fade quickly up there. Mine is off the stern.
As Stephen said
Beautiful yacht! That's a good place for it but I don't have room above the transom hatch. It would have to go to the left of it and then it wouldn't be centered. I may have just enough room to mount is on the vertical edge of the back of the bridge
Dont forget it should fly higher than your USCGAUX flag
When my boat became a CG Aux facility, I was instructed to fly the US Ensign from my transom and Aux ensign from my light standard. This made the aux ensign higher then the US Ensign.........
hard to see... but isnt' there a rail on top of the transom ? i think i see one there... if you have one, a rail mounted staff is your best bet, that's what i did on my old maxum 37.
otherwise, on the end of the bridge, with a cut out in the canvas and maybe a couple extra snapins to hold the canvas down. simple and you should be able to pull out the staff from the cockpit.
Pascal's right
