Which caulk to use
nordeng
Hi - Can anyone tell me the best type of caulking to use before using screws into fiberglass to secure horns, vent grills, etc. I'm just trying to ensure they will be watertight. Thanks.
Life Seal by Boat Life....It is made to use above and below waterline. A little on the expensive side but you will have no worries.
3-M 4200 would be my choice for the applications you mention.
I used 3M 4200 for above the water line. I had a couple of things I used it for last year. Bought a 3oz tube; smallest I could find. I sealed up the tube, and then put it in vacumm sealed bag (foodsaver bag). I have a couple of things I need it for this year and I am hoping it's still good.
If any of the caulking is going to be exposed to UV rays, try Life Seal by Boat Life or 3M 4000 UV. They are not going to yellow.
The 3M 4200 and 5200 will yellow when exposed to UV rays.
I like Sikaflex 291 LOT. The white will yellow but I never have enough of it showing to worry about. Since most of my hardware goes onto dark varnished wood, I actually use black more than white. Any quality soft, flexible polyurethane will work fine for bedding hardware like this.
I use 4200 for mounting things on the decks and hard top also.
