why 2 battery switches?
ocean
I have read many posts on batteries but I am confused about why my boat has 2 switches
One switch is in the engine room the other one is on the electrical panel
Should both switches be on the same setting? and why are 2 switches nessesary ?
No way of knowing until you tell us how the boat is wired. Have fun!
Could the one on the electrical panel be for AC? I've seen boats that have a 1/2/both switch on the AC panel that refers to which shore power cord is being used. Its just a guess though.
I'm fairly certain that both swithes are for the batterys and not for ac
My GUESS would be that the one in the engine room is for the engines, and the one in the electrical panel is for the "house". However we still don't know if the latter is a DC or AC switch. It could be a battery switch or a shore-off-generator switch. "fairly" certain has gotten folks KILLED. So until you tell us we can't say... have fun!!!
How many battery banks do you have? How many engines?
Willie
both switches are DC
the boat has 2 135 for lehmans
1 westerbeke generator
the switch on the panel will start either engine in 1 or 2 positions
there are 3 batteries 2 for the engines and one for the generator the lights etc seem to run in either battery switch position
you got to pull an electrical diagram or if you dont' have one, you're goign to have to trace the battery wiring, and become familiar with your system. I couldnt' imagine owning a boat and not know how the batteries are wired.
typically, the switch in the ER turns on the starting batteries and the switch on the panel turns on the house circuits.
it's not rocket science. shut them off both. turn on the the switch in the ER and see what works! i guess you'll be able to crank the engines but will not have anypower to the house circuits. shut down the engines, tunr the ER switch off. now tunr on the switch on the panel, you shoudl have power to the panel and house system, but not be able to crank.
you must know what turns on what, it's a safety issue.
Every single boat "can" be different, and usually are. First thing you have to do is create a wiring diagram depiction for YOUR boat. I'm very comfortable with electronics and wiring, but having a paper version of the layout still helped me to see things that I did not know/realize previously.
Make it yourself or pay someone. Same thing goes for your fuel manifold plumbing. Have a diagram with the valves show for that too.
Yup, wire tracing time.
Mine has 2 switches as well. 3 battery banks. Switch #1 does bank #1 & bank #2. Switch #2 does bank #3 & switch #1 (whatever switch #1 is selected to). This way any bank can be used for any purpose in any combination.
I had to trace mine the hard way. Turn a switch on, turn a light on, then start lifting cables from batterys till I found which one turned the light off. Simple really. Just takes time.
A friend of mine, who has difficulty remembering which end of a screwdriver is the handle bought a 80's model 32 Wellcraft. Two battery switches, three batteries, no genset.
I chased wires till I finally burned out.
Former owner (this is an E Bay boat, bought sight unseen, first boat ever) had installed a remotely located third battery, and somehow managed to hook these batteries in series. I was using a test light instead of a volt meter (lesson learned) cabin lights sure were bright, stereo had issues,water pump ran like a scared rabbit, took me a little bit to figure it out. Thought he had Halogen bulbs at first. Major pain when you try to follow someone elses not so handy work. I used a labeler to tag every jury rigged wire back to the batt switches. made sure all was fused. Did some under dash corroded wire repairs (Fla boat) To this day he nor I have a clue about the switch position functions. He doesn't touch them and is happy with the way things work. Fortunately he seldom leaves the small bay where his slip is located. And has never spent the night on the boat.(fourth year with this boat)
I suggested he buy a pontoon boat. Sparse upholstery, minimum wiring, will hold his igloo cooler, single outboard, a few seats and he's good to go. . . . . .
Ocean... Sorry but with two engines and a generator and three batteries I'd expect a LOT more switches. I'm a single-screw guy so I'll leave it to the multi-engine experts to figure out (but even then I think they'll want more info). The only twin I ever drove I had a PAID engineer to take care of details like that!
"Former owner (this is an E Bay boat, bought sight unseen, first boat ever)"
Ya gotta love those guys....
This is directed at no single RO, but everyone bored enough to read it:
Knowing what SECURES what is even more important than knowing what ENERGIZES what. You really do need a plan for casualties/emergencies/whatever you want to call them, to IDENTIFY, ISOLATE, and CORRECT issues. This,of course, requires a degree of familiarity with the vessel and it's systems. A great winter project to aid in this is to put together a VDC (a vessel data card is a card or page listing all of the vessels characteristics - LOA, beam, light and loaded drafts, propulsion, tankage, endurance, burn rate, et cetera) as well as cards for the major systems - basic electrical distribution and switch, fuse, and brea'er locations, battery locations, fuel distribution and valve locations, bilge pump plumbing and locations, et cetera. Add in well thought out casualty-specific procedures, and you've got yourself something VERY good to have.
I never went to those extremes but NC is right on target. If you don't know your boat, you don't know ----! Anything else is irrelevant, at least as long as you're on the boat.
