Windlas need help yet again!
hackalar
Ok I'm working on windlass now... It's a Simpson Lawrence on a 95 model Silverton. First, previous owner owner said it quit working years ago and never worried with fixing it. I found wire from dash swith unpluged. Started working but only for 20 secs or less then tripped breaker in ER. After using over and over same thing. Starts out running for 20-30 seconds then trips the more I try the faster it trips. (hot)? It will let chain/rope out but will not bring back In. Sitting in slip I can drop it to bottom (18 foot) and it will not finish picking it up.
I removed it and have it in my garage. I pulled it apart in two. The top where the rope/chain wrap around turns freely. Any ideas? Could the motor be bad? Any way to test?
1) I am going to guess that you have a H series Pro Sport.
2) can you remove the motor from the assembly and run it directly
3) does the motor have replaceable brushes. remove them and check them out.
4) in looking at the Lewmar web site, there is a downloadable service manual. it looks like the gear assembly can be taken apart. check all bearings/bushings. it could be that there is enough corrosion that you are loading up the drive train.
I think it's a sprint?? May be wrong..
I pulled the motor apart and found things in it broke. Should i replace or rebuilt?
Dude, that motor is SHOT. based on the pics, and the fact that it has run for a while, I don't think that the wiring was a problem. best bet, replace.
depending on the model you select, then you need to evaluate the wire size.
The motor certainly is toast, but if everything else looks to be intact it couldd certainly be worth pricing a new motor vs a whole new windlass. Your pic make yours look like a horizontal model unless you just took off the gypsy section and laid it on it side on top of the rest. Here's a parts diagram of the Sprint 500 for example: http://en.lewmar.com/webspares/pdf/windl/sprint-500.pdf
See if you can see a model that looks like yours: http://en.lewmar.com/products/index.aspx?lang=1&page_id=10
Then go to Spares and punch in the Model and capacity: http://en.lewmar.com/webspares/index.aspx?prod=windl and click on "pdf file" for the diagram.
It's too bad not all windlass makers make that info readily available online.
Should I buy a replacement motor or just replace the whole entire windlass?
If price isn't an issue, I'd search for the exact one you want for your needs/boat/preferences and install a new one. That way you will know exactly what you have and not be spending time troubleshooting an old one with which you are not familiar. Newer models are greatly improved over the older ones in their design, etc.
I don't think much of the product. I have a similar one. Simpson Lawrence Sprint 500. Motor died after three seasons. Company was not at all helpful. I ended up replacing the unit with the same one because the hole was already cut for that particular one and I was hoping the first failure was a fluke. This one is going to a whopping 4 years with minimal use and so far it seems ok. Always on pins and needles though
Went with a new one. Replacement motor was $800. Thanks for all your help.
