Here are a couple of quick snapshots of the replacement weather stripping I did on Saint Max using pipe insulation from HD. I am still working on the proper amount to remove from each tube. Cutting it in half seems to make it too loose a fit. The current view is shaved about 1/4 from the insulation.
I know it has to go in in one piece. It looks better w/o seams and stays in place. I mis-measured and stuffed about a 1" piece in the gap. That popped out and is somewhere in the river now.
Personally I like the sheen look over the flat of the original.
I shall keep you posted as to the durability over the winter.
Original
New
Original
New
