Winter on the Chesapeake
van lafermine
I am considering leaving my boat in the water this yr. I have an ice eater but I am not sure I want to leave the boat uncovered. Our Condo assoc. does not let us shrinkwrap our boats in the water. I am trying to decide if it is better to haul, shrink and relaunch in the spring or keep her in and do a short haul in the spring. Obviously I will winterize all of the systems.
My questions are how does the UV affect the boat over the winter. Our winters are fairly mild with not much snow. But we can get some freezing and with snow I am not real comfortable that it will drain properly. I also have a cockpit cover so I could take off all of my strataglass. I also have a hardtop so it would keep most of the snow and weather off of it. I would like some feedback as to what others have experienced.
I don't think UV will be any worse in the winter than it is in the summer... in fact, maybe even less of a concern because the sun is low in the sky and there are fewer hours of daylight in the winter. If you leave it in the water the most important issue IMO is making certain that the bilge is draining/pumping out OK. While we may not get a lot of snow we do get freezing rain which can play havoc with your canvas and your pumps. I say this because one year when our boat was on the hard on the Sassafras we had a snow followed by freezing rain. The weight of all that snow and ice destroyed our shrinkwrap so all the snow and ice fell into the cockpit, later melted and we wound up with 18" of water in the bilge. So, my suggetion is that, if you do leave it in the water, make certain you can check on the boat regularly, especially after an bad weather event.
Originally posted by van lafermine
........ Our winters are fairly mild with not much snow. But we can get some freezing and with snow I am not real comfortable that it will drain properly. I also have a cockpit cover so I could take off all of my strataglass. I also have a hardtop so it would keep most of the snow and weather off of it. I would like some feedback as to what others have experienced.
I lived in MD all my life until I retired. I have shovelled two feet of snow a few times. If your boat is not covered in a way that will prevent snow from building up on it, you could have problems with the weight or with melting snow entering the boat.
Just a caution.
Van, We have a winter cover/s that replace our regular stuff, and I use an ice eater on a thermostat, and have a lg. Boatsafe heater between engines, but also winterize. Never had a problem with snow, and maybe you could consider one of the 30 degree attachments to an extendable boat pole and a squeege type attachment to push or pull snow from the hardtop from the pier. I have "t" fittigs on my bimini that galvanz. pipes fit into to support top, and maybe just some heat in yours will melt anything off the hardtop.
Only things that ever concern me are power outage, and pier being slippery to get down to boat.
Van, my cousin lives on his boat at Castle Harbor. Your location isn't exactly one that gets a ton of snow. Our boat is across the bay in AA county and we leave it in all year. The canvas and the glass stay up, although supported with some 2x4's. After a snow, by the time I get to the boat, it's usually melted off due to the sun heating up the cockpit. We use Xtreme Heaters to avoid winterizing (nothing more fun that a day on the bay in January when it's sunny and in the 50's!) and have survived highs in the teens for a period of 36 hours without power.
As somebody once said to me about shrinkwrap: Why would you want to trap all that moisture in the boat?
And as somebody else once said to me about dry winter storage: Where's your boat kept the other 9 months of the year?
UV is not an issue in the winter. Put on a nice cockpit cover and you are good to go. Shrink wrapping today with the prices they charge is just not needed, its more for the owners piece of mine then good for the boat. Plus makes the marina's tons of $$$$.
Van-
I'm at the top of the Bay and have kept the boat in a wet slip thru 3 winters (and counting).
So far, no problems at all. We do have a liveaboard on my pier who watches over things, but I always go to the boat after any measurable snow or ice to clear it.
I hang 2 de-icers under the boat but only turn 'em on if the ice gets to the hull. In 3 winters I've only used them twice, both during the first winter, and only for a couple days.
As far as cover, I've used the regular bridge and cockpit covers with success, but then again we haven't had a 'big one' in a few years. I picked up a well-used Fisher cover and want to try to use it this winter. It oughta be fun trying to put that thing on the boat while floating!
Here's a shot of winter '07:
Father-in-law kept his boat in all year at James creek for 4 seasons. He is now at Gangplank (both in the DC area). He has never had a problem. He does fully winterize though.
I have my boat at Kent Narrows and have left boat in water for last 3 years. I take down canvas and put up a canvas cover for the bridge. Boat safe heater between the engines, winterize all systems, and nary an issue. I am even considering not winterizing this time, just doesn't get cold enough for long enough for things to freeze up. Sit back and relax and save that shrink wrap money.
Thanks for all your input on this. I talked with a couple of mechanics and they recommend that i pull the boat because of the IPS. Evidently there is a ball joint in the drive and It can fill with sea water, if it freezes I have big issues. Has anyone ever dealt with that?
Van
Van
There's no harm in pulling the boat, but I would check with Volvo on the validity of those mechanic's recommendations. Sometimes "assumptions" get passod on and become "facts". I don't think Volvo would let something like that slip by. Too many boats in too many climates.
Do the mechanics you spoke with work for yards that offer storage? Have you spoken to your dealer or Volvo? It's pretty darn hard for something below the waterline to freeze in Maryland. If you do pull, and that ball joint really is an issue, you better make sure it's completely drained of water. On land, it will surely be exposed to below freezing temperatures.
At least for Maryland, I think winter storage on the dry is a great marketing plan that yards have come up with to double their income.
Originally posted by mixman
......... At least for Maryland, I think winter storage on the dry is a great marketing plan that yards have come up with to double their income.
According to history books, the Chesapeake Bay has frozen solid enough to drive a car across the bay as far south as Annapolis. Not often, but a few times.
I remember seeing ice on the water at one marina.
We're at Grasonville too (Lippincott) and are planning to leave ours in all winter. Just plan to winterize the fw and dw systems, however, not the engines, and we plan to visit.
I've seen ice in our marina in January, but I sure didn't try driving the car onto it. Back in the day on W Penobscot Bay in Maine they used to take horse-drawn sleds back and forth between the mainland and the islands. When I lived there, however, I only saw the bay freeze over once -- briefly -- and it was around 30 below that day.
I am looking into a Boatsafe heater and trying to find a # directly to Volvo. My original dealer is gone and the only volvo certified mechanic is where I would lift and store the boat.
I drove across the ice once, back in '77 I think it was. 2004 was tough too, but I didn't have a boat in the water then.
peace of mind, how much is it worth it to you? since you cant' use the boat anyway, why not sleep well at night?
and at the risk of stating the obvious, dont' forget to check your insurance policy before making a decision!
Considering how many liveaboards there are in MD, keeping a boat in the water all 12 months isn't a big deal. Don't we have an RO on this board who lives on his boat in Canada all 12 months? 2008-2009 we got out at least once all 12 months. Last year we didn't make it out in Jan or Feb, but we were out in Dec and again starting in March. An ice-eater is always a good idea if your marina doesn't have bubblers.
Van, don't overlook Xtreme heaters. Give them a call (you might get Steve, the owner). He'll work with you to make sure you get the correct unit(s). They're smaller than the other brand and use forced hot air, which has benefits over the design you're looking at. I've had mine for 3 years now and love them.
