Winter Refrigerator shutoff?
Radiowaves
For the last 3 years when keeping the boat in water for the winter , I shut both the cockpit and the salon fridges and keep drinks in a cooler. This year I only shut the cockpit off. But I think if it does get super cold for an extended time it could possibly do damage to my salon fridge. I may shut it down for the winter this weekend, but am tempted to leave it running. Anyone else do the same ?
just put the cans in a plastic container that way a leaker wont make a mess.
Brad,
I would shut it off. U can do harm. and if it gets real cold for extended time ull freeze the stuff anyway. But again u can do harm to the frig. SO shut if off..
I shut my off last winter and the fan was frozen (not cold) but rusted to a stop.
Radiowaves, don't know why that w/b any different than the fridge I keep in my garage 24/7/365. I occasionally get a liquid frozen & it can make a mess. I don't know if the cold can damage a standard freon fridge. My garage unit is at least 15 years old.
We leave ours running all year long. My dad owns a refrigeration business and there are a lot
of old freezers that run forever, but sometimes when they are shut down to defrost, compressors
or fans freeze up.
I have seen the same thing in RV and camper fridges. They don't last if they are turned off
for too long.
If it is newer, it probably won't be a problem.
Mine is truned off right now, on Lake Erie, same over the last 25 years, no problem.
I read somewhere that since a refrigerator actually sucks the warm air out of it and dispenses it into the surrounding air, if it is in a location that is too cold, it won't work and you can burn out the compressor. Not sure if this is true...
What about all those Coke and Pepsi machines that are outside in any weather? The arguments here on both sides have points, I'm just wondering if we have any HVAC people around that actually know the answers for the OP? I unload and turn off our chest freezer over the winter as we don't use it, but I keep the refrigerator running 365.
We just turn our down to a lower setting and let it run on AC. We put a few ice cubes in a bowl to verify that the dock current has not been interrupted while we are gone.
I have always understood that refrigerators and freezers are best when kept running. That was a concern that we in the military had when we were shipped someplace overseas and had to leave our furniture in storage. Many sold their refrigerators just to keep them for sitting without running.
G
In Brads case we are talking a small marine refrig. When the temps get too cold the refrigerant gets sub cooled which could allow liquid refrigerant back to the compressor causing damage. Notice use of the word COULD. AS for fan motors locking up. if slight corrosion was the culprit to the fan sticking simply touching with ur hand will free it up. If its more then that the fan would have failed eventually anyway but blaming the layup is the obvious choice. Refrigerators should never be stored in any other positon then there operating position. Laying refrigerators down allows the oil in the compressor to trvel. This would be bad on mnay levels. Commercial refrigerators are designed to run in cold weather as are soda machines. our boat refrig do not meet those standards. Hope this helps ....
Pose a question here and get a lot of good feedback… I see all points, but as Rob stated my small marine NORCOLD may not be suited for sub freezing temps prolonged. January and February can be that way on LI. I really would not keep much in it anyway during the winter. I had been storing drinks in a dry cooler to protect from freezing and bursting.
The points about storing not running can also be a problem; basically I have turned it off around Thanksgiving and back on mid March around St. Pat’s day. Would that be considered off too long ?
Thanks for all the information.
Brad no its fine ... like i said if something fails to work due to that off period it would have failed soon anyway. Look at all the boats on land unplugged. its a non issue.
Brad,
Turn it off and leave the beer on the dock in a cooler. It will stay cold in this weather.
Where are you docked again?
