- Sep 28, 2002
- 10314
- 855
This has been discussed many many times on many forums and it is risky at best. The thermostat does cycle open and closed but not all the way open and not all the way closed. One way to see it for yourself is take a pot, hand a stat from a coat hanger wire and heat it up. You will see how it operates then. Most modern stats start to open at 160 (remember that fact) and are fully open at 180. Now if your engine idles at 160 on the gauge and not higher, when you are running it on the water hose, what does that tell you?? That it is starting to open, not all the way open, and that's what you would need to have happen if you want to use this method without draining the block first. If its just starting to open there is not enough flow for the water in the block to exit. And the antifreeze does NOT get warmed by the block until it's sucked in by the circ pump. What happens is, when the stat is closed, the raw water comes in and gets diverted out the manifolds. When the stat opens, hot water comes out the stat, and exits via the exhaust, the antifreeze comes in the raw water flow but gets sucked right into the big hose by the circ pump and then goes in the block, it does not get heated first, only after it gets sucked in.
About the only way to know if thermostat is really open, is to feel the big hose from the thermo neck to the circ pump. When that hose gets too hot to keep your hand on (150*+) then its probably open. I have an IR temp gun and I have taken readings of the intake manifold right under the thermo housing and at 165 on the gauge, the manifold is 155 or so.
Keep in mind that no manufacturer of I/Os or inboards that are raw water cooled ever recommended this procedure, they say to drain manually for FREEZE protection and back fill with AF for CORROSION protection. That's the safest way to do it......
