From one of Dometic's Owner's Manuals:
At the end of each season, the SeaLand toilet should be winterized for storage, by either draining or using potable water-safe antifreeze in the system.
To drain:
1. Thoroughly flush system with fresh water.
2. Empty holding tank.
3. Shut off water supply to toilet(s), and remove inlet waterline from toilet. Do not remove brass cap on bottom of valve.
4. Press flush lever until all water is drained from toilet(s).
To use antifreeze:
1. Drain potable water tank.
2. Add freshwater antifreeze to potable water tank.
3. Flush potable water antifreeze and water mixture through toilet(s) and into the waste holding tank. Each installation is different, so amounts may vary. User discretion is required to assure adequate protection.
4. Empty holding tank.
NOTE: Use nontoxic antifreeze designated for potable water systems.
CAUTION: Never use automotive-type antifreeze in freshwater systems.
