Winterizing Diesel inboards
I have all ways paid to have it done and although I plan to have it done again this year I would like to fully understand the process as I may need to do plan to do everything myself next year. The more I do and understand this year the easier it will be next. Is there a way to simply fill the strainers with antifreeze or do you need to disconnect hoses too?
If there is an old thread if someone can post a link that would be great.
You have a few ways to do it.
Easiest way: Shut the thru hull, take the top off the strainer, have all the pink open and ready to go. Start the motor, start pouring pink into strainer. Shut motor when done. Replace lid. If in the water when doing this open thru hull when you are on land. Also better if you have extra person to start and stop motor.
Harder way (on the wallet): Pay someone to do it.
No need to take any hoses off if you have strainer.
I have South Bay strainers so I have to take the hose off and put in 5 gallon buckets. Easier with internal strainers.
Are diesel engines the same as gas where you have to make sure they are up to temperature before dumping the pink in so that the t-stats are open?
No.
Diesels are fresh water cooled, meaning they are cooled by engine anti-freeze like your car. What you do have to winterize is the heatexchanger, the fuel coolers, transcoolers, water pump and whatever other coolers you have.
Not much to winterize on a diesel. No fogging, no sparkplugs, simple. Just change oil and feed it pink.
test the coolant to be sure the anti freeze is sufficient.
How many gallons should it take to complete each motor and genny?
Originally posted by Dusty Rhoads
We have 450 Cummins, and I run 5 gal. thru each, and 4 thru our genny.
Wow that's a lot more then I would have thought I'm glad I asked. What method do you use to to fill? I'm not sure about just pouring into the strainers I thought it only pulls from the top and with the lid off can one keep up with the flow? Is there some kind of temporary cover with a hose feed that can be tide into a 5 gallon tank? That would be great and simple to use maybe I'll just have to make one from a spare lid can't be hard to do. I hope I just didn't blow my big opportunity for a patent:) But if I just thought of it it must already be out their.
Dave what we did was disconnect the inlet from the strainer and insert a 3 inch hose with a pvc barb fitting on the end. The other end went to a 5 gallon bucket with AF. Generic plastic hose from HD or Lowes works fine. They probably have the PVC fittings to enable the connection to the hose going to the strainer. In fact, I've never needed clamps on this to make it all work. Well maybe clamps to connect the two hoses together.
Everything has to be ready. AF, buckets, hoses, all ready to go at haul out. Since the engines are warm after hauling they fire quickly on the hard. On the hard route the inserted hose to the bucket and fill with AF. Let the S.O. fire the engine. When the AF runs dry pull the shut down lever by hand. When the engine is shut down, go outside and capture some of the run out and test it.
If it tests low add AF to the bucket and repeat until it's good at the tailpipe. Same deal for the genny.
P.S. change the oils before haul out, and winterize the plumbing with an air compressor prior to haul out as well.
Don't worry, you can pour into the strainer and the pump will pull the pink right thru, pulling hoses off is hard extra work, no need to do this.
The motor will not overheat, the impeller will not burn out, just pour the pink in as fast as you can, it will suck it up, do the 5-6 gallons per motor and you will be fine.
I know I couldn't have been the first to think of this there was someone who beat me to the idea of a temp lid "thoroflush" but from what I have read they went out of business it a shame seems like a good idea. Anyone know of any others?
Robyns Nest if I can't find I will try it your way, but it just seems simple and full proof with some kind of adapter.
My internal strainers are mounted horizontal so I made my own adapter. I had an extra set of end caps from the heat exchangers on my previous boat. I drilled out the middle and put a 1.5" thru-hull fitting on it. I hold it in place with some small bungee cords. The seal isn't perfect but it gets the job done. On my previous boat I just poured it into the strainers.
Okay, this one is confusing me too. If I pull the lid off of my strainer it looses suction and does not pump water. I know this because I had trouble putting the cap back on the strainer after cleaning it once and it did not pump water. Wouldn't pump uless I covered the top with my hand in which case I could feel the suction. Once I got the cap seated properly, it pumped fine. So with the cap off and pouring pink into the strainer I can't imagine it working???
Last year, I drained my mufflers, then opened the top of the strainer, had all my bottles of pink opened and ready to go. Son started engine, I poured in 6 gallons of pink as fast as I could. Shut off engines and I was done.
Same for genny.
The pink lubes the impeller so don't worry about burning it out when you pour in the gallons.
The genset should take less than 4 gallons. I've done a gallon and saw pink coming out the exhaust. I do 2 just to be sure.
Originally posted by The Other Gary
Prospective, that was because your seacock was open.
Yes this is true but why does it matter? Not doubting you, just trying to understand. Is it that it needs the cap on to maintain suction to pull the seawater up from the thru-hull but will suck the pink out of the strainer itself w/o the cap on?
I bought a strainer cap and hole sawed it out, mounted a thru hull fitting in it with the hose side up. I hook the hose on and stick it in the bucket full of pink. Start engine, done. Move cap to other engine, repeat.
we seem to be talking about closed and open systems 5 galons seems a lot of af for a closed system. maybe not for an open one
