Hello Boaters,
I need a little help, I have a 1978 Cruisers Villa Vee with twin GM V-8's, raw water cooled. This boat is a straight inboard with a velvet drive transmission, its not a IO. In searching for information on how to winterize the motors every article I find talks about warming up the motors by attaching "muffs" to the outdrive. I found nothing on a straight inboard.
I'm thinking about 2 different options. One would be to remove the water intake hose from the thru hull, put the hose in a pail of antifreeze and start the motor. When antifreeze comes out the exhaust shut down. One concern would be the fact that the thermostat would not have opened up. Problem? I don't know.
Option number 2 find and pull drain plugs on blocks and manifolds. Then some how fill block and manifolds with antifreeze after they are drained of water. I'm thinking the manifolds would be pretty easy to fill, but I'm unsure as to which hose to pull and fill on the block. Then there's the whole thermostat thing again. Oh and in filling the block, would this get into the transmission cooler?
All this work would be done on land after the boat is hauled out. I don't believe I would have access to running water.
So, anyway to my question. Anyone have a step by step instructions on winterizing inboards or website that has the necessary info?
Thanks for your help, Al
