I winterized the fresh water lines and faucets by bypassing the heater and using the fresh water pump to run anti-feeze through the system. Worked fine.
Then, I drained the fresh water side of the heater. Opened the valve at the bottom and emptied it. Then I used a hose and funnel at the pump/line nipples and pink stuff to displace any water left there.
I need to remove/displace the raw water in the heat exchanger. Pulled the engine hoses off the nipples at the heater, then tried the hose and funnel raised above the inlets to introduce anti-freeze. No go. The anti-freeze just sits in the funnel. I thought a gravity feed would do the trick, but didn't. I don't have a compressor to force the water out. Any other way I can do this?
