Wood flooring
Brian
I have been playing with the idea of installing wood flooring in the the salon of my boat. I know this topic has been discussed before I just can't find the thread. I have three hatches inside. So I need to consider that so I can still get to the bilges. I don't know if I can use something like pergo. I think I would like something that is not a floating floor. Ideas and pictures from people who have done this would be appreciated.
I would not use Pergo or the like. When it gets wet, the substrate blows up like a balloon. BarrenRiver's flooring looks a lot like the stuff we put down in the den. It is a floating floor that "clicks" together without glue like Pergo, but the surface is a 1/8th" real wood laminate (mine is maple) instead of a photograph and the laminate is glued to 1/4" plywood instead of particle board There is an aluminum oxide coating that gives it a satin finish and it wears like iron. Lumber Liquidators has it. No affiliation, just found the product to be superior and easy to install. It will eat saw blades though!
My 2 cents.
"Pergo" type floor - going on two years, still looks great - much easier to maintain than my old carpet.
I installed Pergo in my boat two years ago and was worried about water intrusion. I have had no issues with it and it has gotten wet a couple of times, nothing big though.
I used plastic sheeting underneath, don't remember the mil thickness though. It still looks great!
Would do it again.
Jamie
Hogan that looks great. Did you do yuorself. I noticed the hatches trimmed and all. Also the pedestal for the table ....did you buy that or is that what was in the boat. You could PM me with details. How many square feet needed..etc
My marina did all the work, the pedestal is the original that came with the boat.
Originally posted by pgilbert
So what is the 5th picture??
5th picture is my son's $80k John Deere tractor that got a little warm.
My flooring is 3/8th" Bruce hardwood, glued and stapled down
Guys nice floors. Hogan how else can the hatch's be done. That's my issue. I have two large hatch's and a third smaller one. I'm not a fan of the metal trim but thats all ive seen
I hinged some of my hatches and installed perco pulls. Others I just built a plywood bracket fastened to the outside of the opening and laid the hatch on it so it could be completely removed.
