Woody wax
mawyatt
I know this may have been answered before but I don't recall. Does anyone just use Woody Wax for all fibergalss surfaces? Seems like this may be the least effort approach since it is applied with a deck brush and rinsed off then just a rub down with a towel. If you have a good glass base that's not oxidized then just applying Woody Wax every 2 or 3 months should keep things in shape without the need for the serious machine aided (Porta Cable 7424) polishing and buffing with the regular waxes. Just looking to make my boat maintance life easier!!
I do all my cleaning with woody, love the smell of it. However I have a cleaning company do my waxing trice a year.
I haven't tried it but I understand it's very good on non skid because it's easy to apply and doesn't make it slippery. I recently bought the Porter Cable and it works very well. It's a little heavy though.
I don't use Woody Wax, just a big bottle of Jergens and some Kleenex..[:-eyebrows][:-eyebrows]
You man-whore! Clean up needed here! ;)
Woody Wax is a good product, I've used it and recommended it, given the right use.
Bottom line, its not such a good product that I would recommend it as being "easier" or just as effective as a full fledged wax product. That's not what I would recommend it for. It's not very long lasting and not as effective as a regular wax. However, it is easy to apply AND it is "thin" enough to act somewhat as a solvent for old faded gelcoat. When you have old chalky colored gel that just won't shine or lose its chalky look, even after compounding, try a little woody wax on it. It really penetrates and shines better than any other product I've found for that. Of course, its also nice on nonskid.
If you fish, and need a waxed surface blood won't soak into, keep the woody on hand and apply to your cockpit, it will keep the wax fresh and help to keep the fish mess down.
So, good product, but probably not for what you are trying to achieve, which is to avoid the need for the full meal deal waxing effort.
I use Woody Wax for the non-skid. Love it. Haven't tried it for the rest of the boat, but seems like it wouldn.t last long.
I use Woody Wax on my non-skid only. Makes cleanup after a day of fishing easier...that being said, after a couple of scrubbings you need to re-apply.
It's pretty expensive. I can't find it for less than $27 for 16 oz.
A fellow on another forum brought this up regarding WW. I don't know much about it but thought I'd pass it along. Maybe an alternative?
________________________________________________
Want a cheaper alternative to woody wax. for the past several years i found a product that works just as well. it comes in an aerosol can and can be purchased for about $8-9 at i believe tractor supply, atlantic tractor or the internet............its called FLUID FILM. its hard to find up north but very popular down south.....just google "fluid film"
the application process is exactly the same as woody's products. exactly. funny thing is both products must have some of the same chemicals..........just smell both products. they even smell the same. now put the savings in your gas tank.
I use Fluid Film on several lube situation and it works very well. I was considering Woody Wax, but after reading the contents, realized it is a petroleum product that will make things bright but not for long. I think you should either be using a polish or wax ?
I buy Fluid Film direct just google .
If you have a tuna tower or a lot of aluminum, this stuff is great. Put on a pair of latex gloves and spray it on the aluminum and rub around with the gloves. DO NOT WIPE IT OFF. Leave it one for a week or so and then wipe it down levaing a bit of a film. It does a great job, but you NEED TO LEAVE IT ON FOR A WEEK...
