Originally posted by jtybt15
and Fords were 3800-4200.
Best economy is acheived when running with the highest vacuum reading for your desired RPM. That means running with the throttle open as little as possible to maintain your RPM/speed.
So going back to some of the basics, the faster you go(with a deep V planing hull), the higher the boat will run out of the water. That gives you the smallest wetted surface and the least drag. To get your best economy run up to your target RPM(or speed) and a little faster. After you get there, incrementally back off the throttle and you can maintain your target RPM by running the boat slightly higher out of the water which means less drag and less throttle needed to maintain that speed.
...of course, rough water knocks that ability out the door.
