Yep, gas is explosive
Fire Marshall states that the boat was being fueled at the time. I'm not sure, as it is hard to tell from the photos, but it appears that the boat was in a slip, not at a fuel dock. If so, they were re-fueling in the slip, a practice that I discourage my neighbors from continuing...
Who would have thought gasoline could explode? [:-boggled]
I understand it was a wooden '68 44' Trojan that blew up...
Bill, I'm not trying to be a smarty-pants or anything, but why would it be dangerous to re-fuel in your slip?
Simply, it exploded from the static electricity built up from the fuel traveling from one container to the next with out being bonded. This is just my assumption, I was a fuels guy in the Air force and we had a Jet blow up for that reason. fuel filling stations have metal filler nozzles to bond the two containers just like the one at your local gas station.
It funny that Jets in the Air force run on High grade diesel and can still explode, or rather burn rapidly. fuel made from petrol does not actually explode, It burns at a very high rate, making it seem like it exploded.
As for fueling in a slip, I do it all the time, I just make sure whatever I'm using to fill my boat with is bonded to the boat.
Bob, some of the reasons include: not having fire or spill equipment nearby ( as well as other persons to help deal with problems ) and burning up other boats along with your own. As well as usually not having proper fueling equipment. I know a gas pump looks fairly plain, but it is designed to be simple and safe as possible. Fueling at the slip rarely has these safety features.
-edit-
livingaboardboy: In the USAF, didn't you usually have a someone stationed nearby with a fire bottle? And didn't you fuel the planes at a fuel stand, away from other aircraft to avoid fratricide?
"Bill, I'm not trying to be a smarty-pants or anything, but why would it be dangerous to re-fuel in your slip"
Bob, if you are fueling in your slip, you are probably pouring from 5 gallon cans, which are not grounded and diffucult to keep from spilling. You probably do not have fuel spill cleanup supplies readily availabel, nor proper fire fighting equip. Our marina allows you to bring your own fuel if you desire, but you must refuel at the fuel dock for the above reasons.
Every marina I have ever kept a boat at has prohibited fueling at the slip. In some cases the mandate comes down from the local fire marshal but the marina's insurance would also dictate it.
At the gas dock there are (or should be) fire extinguishers and/or fire hose available. The gas dock is usually closer to a spot where a fire truck could get access to. If your boat does catch fire during the fueling process there is less collateral damage that will result.
Rod
All you older boat owners, take notice: most older boats has a "static" ventilation system in the engine room. Upgrading to a proper bilge blower system could save your boat and, perhaps, your life!
Note to parents: wouldn't you want your young child to be in a PFD if your boat exploded and that child got blasted into the water?
Note to skippers: all passengers should be off of the boat while fueling and ventilation takes place. Make this a cardinal rule on your boat.
( Uh, oh. Flutterby got her "Mommy" button pushed. :) )
Yes, m'am.
Do you actually have a point with that statement?
Here son, put on this PFD because daddy is going to blow up the boat today and blast you into the water.
We usually don't plan accidents. That's why we wear safety equipment.
So using your logic, I can ascertain that you walk around wearing a bullet proof vest then.
Better yet, you must wear a full fledged fire suit when fueling your boat.
This started out as a serious discussion. Let's try to keep it that way.
Well, wouldn't/shouldn't your kids have PFDs on anyway, if you just pulled up to the gas dock?
Get a diesel powered boat. Your kids can smoke while you fill the boat with diesel fuel.
