Originally posted by Sandy
Are the output/coupler fasteners by any chance contacting the transmission casing. ( That can happen on some Velvet Drives, dunno about ZF.)
Could the noise actually be transmitting up from a shaft donut that has slid down to the strut, or loose pancake anodes on rudders or tabs?
Or, if you happen to have them , Spurs line cutters with worn nylon bearings allowing them to contact?
If you are sure it is internal to the transmission or reduction gears and not say, a broken damper plate spring, it may be time for professional assistance . Still, it doesn't sound too serious if it's only evident around idle.
Has that engine had a good tuneup recently so idle in gear is very smooth? And what is idle rpm in gear, - set to spec.?
From ZF site:
"What oil is in my transmission?
Models 5 through 85 will primarily use automatic transmission fluid. Models 220 through 60000 will use 30W. Refer to ZF oil list for specific instructions or contact ZF."
From Foley Engines:
http://www.foleyengines.com/resourc...rine-transmissions-ins-and-outs-basic-service
