Originally posted by Britanic
I have a 88 34 silverton with 350/270 crusaders - you probably have 454.
First question - do you have a manual fuel pump?
Second question - did you add anything to the fuel?
Dont rule out the engines ignition system yet!
Zach,
Here is what I would do;
Empty the contents of the first (from tank) filter into a clear container, even a zip lock bag will work. If there is any water it will show quickly. I doubt you will see any and dont think your problem is bad fuel. I have found that "bad fuel" is rarley the culprit.
I am pretty sure you have one tank and as someone else said, if the other engine is running OK from the same tank, can't be the fuel.
On the mechanical fuel pump. Remove the flame arrestor from the carb and try to find a vacuum line conected to the carburator. It will be a flexible rubber hose. This will lead to the fuel pump. Remove the hose and make sure it is clean. Then make sure the fitting in the carb is clean and clear, to be prositive blow into the fitting, it should pass air easily. Then make sure the fitting on the fuel pump is clear, you can inset a small philip head screw driver in the fitting.
If you are having trouble finding the fuel pump follow the fuel line from the tank. The pump will be mounted to the engine and will have metal lines running to the carb. If your pump has wiries running to it, it is electrical and you will not find the vacuum line.
IF you have a mechanical fuel pump, this vacuum line could very well be the problem. If your fuel looks clean and the vacuum line is clear, check the anti siphon valve.
My opinion on fuel additives (with the exception of stabilizer for winter storage) is not to use them and run the boat often instead. This is also the opinion of several marine mechanics I know.
Good luck, and keep us posted.
