Well, there are some purely practical limits:
If you fill up the bilge with pumps...
And then there is how much battery capacity you carry. Pumps are not exactly low current items, and then there is the question of duration. So the limits do exist. Mostly, add pumps till your "sleep limit" is satisfied.
I suspect that, for many, that will be one primary and one secondary pump per watertight section. ie: in each section/compartment you will have two pumps mounted one low, one 2" to 4" higher, with staggered switches as well. This will allow one ( with the low switch ) to handle ordinary de-watering chores, and the second should kick in only if the first is unable to handle the load either due to pump failure/clog, or due to rapid influx. In addition, since you have activity indicator lights on each pump, you will know if a) the first pump is handling it, and b) no it is not, the second kicked in...
For me, this meant one 2000GPH ( low ) and one 3700GPH in the aft section, and then I upped the mid-section to one 3700 ( it never collected water in normal usage ). This would have given me several hours of full pumping capacity on batteries alone and a moderately high rate of flow. If the leak was much larger than than, I likely had other issues to deal with that would be more critical.
But you are the one who needs to bring the system up to a level you can "sleep on". And therefore it is you who will decide when enough is enough.
I know I ( and others ) have stated that a pumping system is unlikely to prevent sinking. We are mis-leading you to some extent. IF the hole is "small" ( whatever that means ), it is possible that the pump system will actually handle the incoming flow. In this case, sinking is prevented
as long as the pumps keep pumping. Hopefully this will be long enough to plug the leak, beach the vessel, or actually get the boat to a sling and hauled! But, this fortuitous series of events can only be hoped for, not planned upon. All you can truly hope for is to delay the process long enough to discover and cure the issue, or to make an organized exit from the vessel.
The whole idea to the planning, and certainly at this stage, is to assume that Mother Nature is going to have a field day with you and the boat. That means plan for the Worst Case. If you encounter an "event" and it is not as bleak as "worst case" then you may have a very happy outcome. And if it is, good planning and prep will at least give you the best chance of allowing you time to exit safely.
The best case, of course, is that this is all a waste of time, effort, and money, and you never, ever need the system. That would be nice. But don't bet on it.
