Once again, you are missing the human factors issues. Do you want to study your panel while you are running a tough inlet, or navigating around a dock, making way during a pop up rain shower or do you want to operate your boat? Do you want to try and hear a buzzer over the engine noise and try to figure out what buzzer, and what that means while you have a huge hole in your boat?
Look, let me give you an example. I have an overhead panel on my airplane. Up there is hydraulics, electrics, fuel, anti ice and enviroment management. There is a light, (in fact about 100 lights) that warns the battery charging has failed. It says, "Disch" on the DC electrical. Now do I need to see that light? Answer is no. In fact the light can be inop and I can still go. Why? Because the SICAS (on a Boeing EICAS) beeps a 3 second beep, illumintes a "Master Caution" light right on my glare shield and on a screen right in front of me says, "Battery Discharge". It continues to beep every 5 seconds until I silence it. Then it knows I have aknowledged the alarm, the visual remains. I don't have to be constantly scanning my panel to know what is going on with the airplane. My Lexus monitors things like "Transmission Temp". Do I have a transmission temp gauge to monitor? No, but if that problem arises, it beeps, it displays Transmission Temp I then know I have the beginnings of a problem before the transmission fails. There are dozens of things that my car monitors that display alerts, directly in front of me with a beeper if they go wrong. I don't have to monitor a panel, figure out what is going on, it tells me directly "if and when" those events happens
Let us take the current marine fire extinguishers. They are designed so that the "Light on" indicates continuity and thus the extinguisher has not discharged. This is counter intuitive according to numerous human factor studies. A "dark panel" means all is well, any light should mean something is wrong.
Having 10 different beepers and lights scattered all over hell's half acre, some supposed to be illuminated, others not is not an alerting system. It is a set of disraction devices that may or may not be noticed.
You might say this could be expensive. The answer is no. Consider the electronics involved in you Casio watch that costs 30 bucks. LCD display, display driver, computational chip. We have bilge pumps that automatically detect water through motor load, why can't there be a "motor loaded" NMEA 2000 output? Answer is lack of vision and understanding.
The kind of thinking you guys are displaying is the kind of thinking we saw 50 years ago in aviation. "Oh, he screwed up, he did'nt see that light." Well finally someone said, "Nobody intentially screws up, why did'nt he see that light?" Nobody leaves their home in the morning and says, "I think I'll crash or participate in a sinking."
