Capt10pat I'm not sure I can agree with your assertion that fuel tanks don't become more dangerous as level gets low for reasons stated above. However you correctly point out that its a moot point in this particular case because the fuel tanks did not explode...
But lets address some of the points in the article:
"According to people familiar with gasoline-powered boats, explosions such as the one that sunk the Dodge vessel are not uncommon because of the potential for fumes to collect below the deck.
Larry Bigando, a volunteer firefighter and captain of the Marine Fire Rescue Unit of the Kingston Fire Department said Sunday that gasoline-powered boats are most dangerous when their fuel levels are low.
Bigando said boats come equipped with blowers that must be turned on prior to engine start-up to exhaust the fumes that build up in the boat's compartment.
In an inspection of the craft, authorities found that the vessel's blower motor appeared to have not been used and the power switch was found in the "off" position, according to the Sheriff's Office.
Authorities said Dodge confirmed in an interview with sheriff's investigators that he did not use the blower motor before attempting to restart the craft.
The investigation of the vessel also revealed a loose coil wire on one of the boat's engines and that the alternators on both engines were not sealed."
Regarding blower usage, please consider the fact that running the bilge blower for 4 minutes is only required prior to starting the boat, all boats are designed with non-mechanical flow through ventilation, and prior to 1980 there was NO REQUIREMENT for a mechanical ventilation system.
http://www.uscgboating.org/safety/fedreqs/equ_vent.htm
Now granted this was a gray area because the boat had been running and then conked out, but the owner was not doing anything wrong presuming he had shut the bilge blower off after starting his vessel and pulling clear of the dock. In fact, the vacuum created by the other operating engine would have acted to draw outside air into the bilge and help ventilate the vessel as well...
The fact that so much gasoline vapor was present in the bilge even after the engines were started and the boat had left the dock leads me to believe that there was another problem somewhere. Someone above suggested the engine flooded in trying to restart - that is a distinct possibility...
Of additional concern are the non-ignition-protected alternators (did he buy a car alternator? a BIG no-no) and to a lesser extent the loose coil wire, because the coil is up high and the gas fumes collect down low...
As capt10pat says above - some things you take seriously. It would be a shame, as I suggested yesterday, if this guy had put all that blood sweat and tears into making the outside of the boat spotless and then neglected the engine compartment. He'd have been better off with a ratty-looking boat that was in perfect shape mechanically. I don't know if he did this, but never EVER skimp out and put automotive electrical components into a boat. Period...
Also, if that engine was flooded it means he tried to restart it for awhile. He should have opened the hatch and took a look in there. Never keep trying to start a downed engine without taking a look to see what the Hell is going on in there. If for no other reason then opening the hatch will help ventilate the bilge compartment...
Finally, as I mentioned yesterday I'm in the middle of all kinds of mechanical work on my own boat, that started when I found some electrical system problems and ill-fitting ignition wires. Now you've all got me thinking about those alternators - I just got the boat last year so have no idea when they were last worked on or whatever. How do you tell from looking at them if they're marine or not???
