- Mar 2, 2000
- 36
- 6,660
Pete, you are a bit presumptuous here. Have you ever looked under the hood of an old idling car with old ignition wires at night on a hot humid evening? I'd be willing to bet the alternators were low on the list of sources of ignition.
The points in the distributor, or the loose wire on the coil, or the starter motor, or the spark plug wires, or a hot exhaust manifold would seem to be more likely causes. Perhaps a regulator relay on the alternator did the deed if there is such a thing, but there are so many other sources of ignition. Given that, I'd rather wonder about the source of the vapors. That's something that is probably more paramount in the discussion since we cannot guarantee there will not be any ignition.
But, I do agree that redesign to keep vapors in check is a good thing.
