Originally posted by JimPend
If it's the advance those won't fix it.
Next time you have a problem, help us out. Start out with I have a 454 with ???? hours, here is what I have done, what else????
Originally posted by imspacemancraig
There is a way to tell if you have a reverse running engine or if your tranny and v-drive take care of that. I am trying to remember how to tell. I am searching for it right now. But another way might be to grab the serial numbers off your engines and give Crusader a call to have them check it out.
I think there is another way to tell. Someone correct me if I am wrong, but when you find the metal plate with the serial number, it shows the firing order too. Check to see if they are the same, then you know the engines rotate in the same direction. I thought Carver only used engines with the same rotation and then used the tranny/v-drive to make the change. I know mine are identical. I can swap my carbs, distributors etc. for testing purposes.
I'll keep looking, but I know there is a simple way to figure it out.
Originally posted by Carvervirgin
How many gas tanks do you have? I had a similar issue but only when I was using the port tank. If I ran the engine off the auxiliary tank, it ran fine. It was he anti-siphon valve on the tank that was the issue. Worth checking, for it was an easy fix.
That won't tell you that for sure. Mine say the same thing and I know for a fact the engines are identical turning. The metal plate on my engine even has the same RH and LH on them. I think all that really means is the port vs starboard engine.
Push on the center springy thingy and see if it's springy.
Originally posted by Salvatore356
I would give the engine a complete tune up wire, plugs, you should have a module, coil and rebuild your carb. I did it every 3 years. I also change fuel filters begin and middle of the year. Your engine sounds to me like fuel, carberator needs adjustment your jets can be dirty and inline filter. Just have someone rebuild it for you.
