Carver Pin Striping
Guys - This is my last update on the striping project. Thank you for all of your help and guidance here...it made all the difference. My project did not yield perfect results, but, pretty darn good for the first time attempt. The striping is now on and I designed a graphic for the name of the boat. Again, thanks!
When you guys installed your striping, did you spray a water/soap solution on the hull, or did you do it dry?
Kenny,
I have a 97, 355 ACMY, and I am looking at replacing the striping on the front of the fly-bridge. Can you tell me if Carver had that striping custom made for going around the corners of the bridge, or is that just a roll of striping that the installer installed perfectly with no creases?
On that model, it was just on the roll and the installer rolled out perfectly. It's not that hard, really, as I just did the bridge of my 98 310 Santego with no wrinkles or creases
Thanks Kenny for the quick response. I assume I can get this stripe from my local Carver dealer? I think I saw where you said you still sell the striping?? Can I get it from you if my local dealer cannot get it? Thanks.
Yes, we should have some in stock...if not we can order it. Just need a measurement as they make a couple of different sizes for trim and a couple sizes for boot.
