I got a 1/4" yellow nylon rope wrapped around my starboard engine prop shaft.
Fortunately, I was able to cut all the line off.
Upon further inspection (underwater with a mask on), I noticed that some of the rope is stuck in the cutlass bearing. I pulled as much as I could out but there is still some in it.
I can turn the prop by hand and it doesn't seem stiff but is this something to be overly concerned with? Should I have the prop removed and the cutlass replaced / cleaned?
Thanks for the info!
