Originally posted by pdecat
Ron:
That six inches of water is probably just from a fall storm with high tides. If this storm continues its current projected land fall in south NJ then LI is in the high wind side and the prediction is for a long period of southerly winds. Under normal conditions the south bay flooding is from water pushed to the shore from the bay. There probably isnt enough water in the bay itself to flood very far inland. However if you add the several inches of rain flowing to the south of the island that increases the flooding. Then the big IF, if the storm is strong enough and lasts long enough to significantly overtop the barrier islands then there is a lot more water in the bay for flooding.
This storm has a very big a wind field so it will effect the coastal areas for a much longer time than previous storms to be considered similar to previous experiences. If the windis strong enough in storms it often seems that there is no low tide each high seems to build a bit on the last high while the low is hardly noticeable. Personally I never liked driving my cars through salt water flooded streets.
It is surprising to me that so much of the north shore is being warned about flooding. All I can guess is that heavy storm run off to the low areas is expected to butt up against a very flooded LI sound.
[snip]
