It seems to me there ought to be a concept here of a "rule of thumb", something that, coupled with a bit of common sense, will keep a novice out of trouble. And saying that "boats under x feet, whatever you may see x as being (but certainly x is greater than 16,) don't particulary belong in the ocean, especially when inlets (where conditions change rapidly with the tide or a wind shift) are involved in getting there and back", is a useful thing to have floating around as a general rule.
Sure it's a 90/10 or 80/20 situation. Sure there are special purpose 16' boats that can go out there, and some larger boats that shouldn't. Sure there are conditions when no man made vessel belongs on the ocean. So what? It doesn't make the rule wrong that there is an exception to it, or that it's inverse isn't also true.
The vast majority of the time, a bigger boat will have more and better equipment and systems, will have more freeboard, better resistance to shipping water and capsizing, will take longer to sink from some leak, etc. It's all been said here before. On any given day and given any 2 boats of differing size, and the same captain on either one, the bigger one is generally safer. It's obvious, so obvious that it's pointless to even debate it.
You go out there in a 16' boat, and sink and die, face the fact that the vast majority of people reading about it will think you a damn fool for having done that. I know I will. So if you break the rule of thumb, either be real sure you are right about having a valid exception, or decide you don't care what people think of you, in which case why post on a forum about this at all?
