Originally posted by rommer
In this case that would be a bit like calling Elmer Fudd a hunter Riverratt.
Originally posted by blouderback
If you're lucky. Drain the water, squirt some oil in the cylinders, change the oil, run it on the muffs for a few, change the oil again, and maybe repeat the whole process again. I injested water into my old 3.0L Mercruiser once, and this is basically what the shop did for me. They did pull the heads and replaced the head gasket too. I guess I was lucky - no bent rods or valves and no damaged cylinders. Only cost me $1200, mostly labor.
And lastly, I still have not had anyone specifically point out advice that I gave that was dangerous, so please stop saying that.
After a spirited discussions, I've found that using a bilge blower to ram air into a carb will probably not increase HP.
