Jabsco head leaks
WICKERSWAY
The head is Jabsco (circa 1996)
The part/model #'s I found are 29090 - 37055 series and has the electric conversion kit installed
Small leak that appears to leak at the gasket between bowl & Base
Is there a service/repair kit available for these units or do I just replace that gasket? Are there other gaskets that may need replacing?
If someone could point me to kit/part numbers
much appreciated
THANKS
here: http://www.jabsco.com/files/itemdoc142681.pdf
http://www.jabsco.com/files/0663-qf_conversion-eng.pdf
Looks like the part you're looking for is # 44101-1000
Before I ordered anything I'd take the old O-ring to a good hardware store and see if they can match it.
Possibly some sealant or even grease will solve the problem.
Jabsco has a kit for you. Give them the serial number when you call. They will return your call same day if you call early enough They might. Recommend other parts to replace while your at it. Very inexpensive fix
Try mike at 978 282 5227. Have the serial number ready
I've got a number of new kits that I just took off the boat (they were spares I kept that I no longer need with a new head from Raritan). If you want any of these kits, I'll let them go for well less than retail (and I'm also in MD).
Used Jabsco Electric Conversion - 29200-0120
Jabsco Service Kit - 29101-000
Jabsco Bowl Mounting Kit - 29047-000
Jabsco Intake Seal & Elbow - 29048-0000
Jabsco Major Service Kit - 29045-2000
THANKS ALL
I'll take it apart this weekend.
Hoping it's just that gasket at the base. I thought there might be other possible places that might leak but from the drawings looks pretty straight forward
Mine leaked at the base last year. You'll need the bowl mounting kit if so. I've got part #29047-000 brand new in a bag at my office in Baltimore. $20 shipped to your door if that's the one you need.
I replaced mine today while doing some other PM work. Very simple
Sounds good how do we make this happen
my cell 202 369 6906
