Looking for info
tr_guy79
I currently have a 22-foot Bayliner Aft, and with the addition of the little one (2 years old now) want to move up in size. I have had my eye on a mid 70's Marinette 32 Express Flybridge for about a year now. The admiral wasn't keen on it last year, but we both played hooky on Tuesday, and I took her to see it. She now is in love with it, and wants it in the water this year. I have the opportunity to purchase this boat for $2k as it sits, or with freshly rebuilt starters, and (replacement) rudders and shafts, and props for $3.5k. Inboards are a WHOLE new ballgame to me. Can diagnose and fix about anthing on a Volvo I/O though.
The better half and I are in love with the boat, and considering that we are not rich, this presents a great opportunity, but also a LOT of questions…
1. What size SHOULD the rudders be?
2. What material for running gear, or does it matter. Bronze/SS?NiBrAl
3. What size/blade/pitch props should it have (twin 225's). Not sure on trans ratio yet
4. What size should rudder shafts be
5. What model transmissions does it have?
6. What is the best way to check them out of the water
7. What model were the original carbs
8. What is the dry weight
9. How do I test the operation of the “stray current" (Capac) meter when not in water
10. Can the transmissions in it be freewheeled
11. What size are the fuel tanks
12. What is the minimum plane speed/gph
13. What is maximum speed/gph
14. How do I determine if I can slap an ablative on the bottom, or if a full redo with barrier coat is needed. Can bottom be touched up
15. What should I expect to pay some one to redo the bottom (parts/labor)
16. Can the top sides be done with Krylon
17. Is there an easy way to check the run out on the prop shafts
There will NOT be a survey. It is an ALL aluminum boat. only wood is cosmetic. I will checking the hull for pitting, checking engines (will they turn, what is compression), and do a close all day look over on Saturday.
I know alot of these questions are tall order here, being this is not a Marinette site, but I have never felt a lack of response on any of the posts I have ever made, so I figured I would throw it out there. Thanks to everyone for any feedback
1. No idea
2. All of them work, but require different handling and $$$
3. Best to ask your favorite prop shop.
4. Don't know
5. You should be able to tell when you inspect the tranny...
6. Check what? The tranny? Don't know.
7. Without knowing what engines you have there can be no useful answer.
8. Don't know.
9. Internet search for the owners/diagnostics using the internet. You'll need mfgr and model/serial #
10. Depends on which trannys you have.
11. It's an older boat. No telling. Could be originals or replacements...
12. No idea
13. No idea
14. Don't know.
15. Others will be better able to answer than I can.
16. Why Krylon? There are better, marine grade paints.
17. I'm pretty sure there is, but I don't know it.
That said, why do you not want a survey? A surveyor will answer most of these questions, as well as determine which systems can likely be left "as-is" and which need attention. Note that Aluminum boats can corrode, and a survey is a good maintenance procedure. It is always worth having a second set of eyes look over -any- new boat, and having an experienced eye is a very good plan. A surveyor may cost a few bucks, but almost certainly the information gained will both save you money in the medium and long run as well as help discover areas that need attention.
Questions 1 through 4 are "odd". Is there a reason to question that what you have is correct? ( Again, ask the surveyor ).
Questions 1, 2, 3, 4, 5, 6, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17 can all likely be answered by a surveyor.
Honest. I'm not attempting to be flip or derogatory. The easiest, most accurate start to the info gathering process would be a survey. Trust me; a surveyor will spot things you ( ot I ) would miss. They may even have experience, or loss reports that will clue them in on "trouble spots" that deserve closer than average examination. It is very rare indeed that you here of someone who, after the fact, feels that the survey was cost-ineffective. A good survey really is worth it. Even on a tight budget ( perhaps, especially if on a tight budget ).
Much of this info -could- be gotten from a responsible previous owner, but I do understand that is not always the case <<sigh>>.
Bill,
Thanks for the feedback. The engines are 225 hp 318 Chryslers, with unknown hours. This boat was a repo of sorts. The guy was living on it at the marina, and when he could not come up with the yearly dues, he just signed the boat over. The boat currently has no props, rudders, or rudder shafts (sold by marina owner to recoup losses), and has been sitting on blocks for a couple of years. My sister is good friends with the owner, which is why he is willing to make the deal he is, but I need to make sure that I am getting the right stuff for running gear. I read somewhere that bronze should not be used below the water line on an Aluminum boat. The reason for no surveyor is that as long as the engines turn over and have good compression, the hull is not pitted, and transmissions are ok, I WILL be buying it. At this price anything else would leave with equity, not that one should really worry about that with a boat though. It supposedly ran when it was yanked, but they cannot remember if it was winterized.
My impression is that a survey costs about $600, and on a $3500 boat, that just is bad fiscal planning. Anything that is wrong with the boat I will be fixing myself, with the exception of the bottom painting, which sounds to be a real PITA. My reason for the "Krylon" question is that it is cheap, quick, and easy, and if it got me through 1 or 2 seasons looking decent, it would be worth it.
"cheap, quick, and easy," When working on boats I have found that using this formula is very accurate "Good .. Fast or Cheap" pick two!!!
Good luck with your project, as one who enjoys working on wooden boats and has restored a few, I share your excitement withthis project.
I think you will have a hard time finding insurance without a survey.
Good luck!
In this case, getting a survey has nothing to do with the purchase decision: it is an assessment of what needs to be fixed ( and in what order ). Considering the cost of one error in the repair process and the time/labor required to recover from the error, the survey will almost certainly pay for itself and probably very quickly and be one of the best things you buy in this whole process. Your decision, however.
re: Krylon
If it were just the cost of paint that was involved, then you could use whatever you find at the salvage store on deep discount. But the cost of a "top side paint job" is mostly -not- related to the cost of the paint, but to the labor and materials of the surface prep and the actual labor of applying it. Krylon is not really designed for marine duty. It might look ok for a while, but it almost certainly will fail prematurely. By using a paint designed for this usage, you will avoid a repeat of the removal, prep and paint labor and materials. ie: Using the right paint is cost effective, even though the up-front cost is higher. Again, the decision is up to you, but you did ask for opinions...
Re: the rudders
There is more to rudders than just a "stick in the water". Shape, material, weight, and overall size, as well as "minor" details such as shaft offset of any ( not all rudders have the shaft down the axis ) and/or the possibility that there is a hole in the rudder to use as a prop shaft pass-thu. You really need some details from the manufacturer, or at least, plenty of access to an original so that you can clone it.
You have a major project ahead of you and it will most certainly be interesting. It has great potential to be expensive, as well. I am concerned that your "other half" wants in in the water this year. That is a much tighter schedule than I believe I could keep to, even if I threw lots of money at it.
Good luck, be safe, and happy boating!
Bruce, Marinettes are Alum., first time i hear about a Fiberglass Marinette...
If you use paint (topsides or bottom)with a metal compound in it (most do)you can seriously corrode the aluminum through galvanic action. You better get the right stuff.
This is one example of why you should get a good survey ptherwise you are cruisin for a bruisin!
You are getting a good deal for a fixer upper. It will take a year of spare time to make water ready. Krylon is a bad idea. Go for the $3.5k with rudders and shafts. especially if this is installed. If you don't want it PM me.
BTDTGTTS! Anticipate ~$21,000 and 2 years total investment when all is said and done. Get one off the site for much less and go boating.
Let me clear a few things up.
- ALL Marinettes ARE Aluminum (aside from the house boats built after selling the name)
-I am not getting a survey because
1. No sea trial can be done
2. Oil analysis of 3+ year old stagnant oil is pointless
3. There is NO structural wood to worry about
4. Engines do not (currently) run
5. All fuel lines (in & out) will be replaced
6. I know the paint is shot
7. All blowers will be replaced
8. Flame arrestors will be cleaned
9. There is no 110v system
10. I am fully capable of looking for corrosion, and know what it looks like
11. I have 5+ years in 12v electronics and wiring
I said from the very begining that I would not be getting a survey. I also smoke 15 cigarettes a day, talk on the phone during lightning storms, test 9v batteries with my tongue, eat sausage pizza that sat out over night and have rebuilt carbs on the kitchen table. I am FULLY aware of the benefits of a survey. If you would like to pay for me to get one, I gladly accept paypal rb2@gr5t trguy(at)hotmail(dot)com. Now... Moving along...
Krylon - I would be doing it as a simple 1-2 season bandaid. A couple scuffs of the old, and spray the new. Boatpoker, If i get the boat, I will definately look at the metal content before spraying. The goal would just be to make it look pretty for now, while I address any mechanical issues. A boat doesn't have to be concourse material to be enjoyable. Just (safely) run and float.
As far as the rudders, I WISH I had the option of seeing the originals, or that Marinette hadn't shut down. I will have to find another owner that would let take a look at theirs ('xcuse me, may I look at your rudders...)
Through research I have found that it most likely has 1:1 velvet drives, and needs 14x10x3 cupped props. I will verify saturday.
The engines are clean, and FWC, so that has me hopeful.
Boating requires mechanical ability, and money in disproportionate amounts. I am 5% money, 95% mechanical ability. If anyone has any feedback (other than "you should get a survey"), let me know. I am all ears.
Shane
Ok.
Obviously I'm not helping. Enjoy your new boat. Let us know how it goes.
Bill, I never said you weren't helping. Just a little frustrated in the first post I made it clear that there would be no survey done. You info on the rudders is helpful. As I stated, Inboard is all new to me, I was unaware the variances if different rudders. I am trying to picture prop shafts running through the rudder shafts though, and cannot figure how or why.
-Shane
The problem is:
Getting the right info will involve getting it from one of the following:
Manufacturer/Original Plans
Current Owner
Surveyor
Marine Architect/Engineer
The first is almost certainly out, the second is unlikely, but possible given luck and diplomacy, the third is not cheap, but affordable and the fourth will give great results and a high price. It would be nice if there were another solution, but I'm stuck with the four above.
The reason a surveyor was suggested is that the answer to most of your questions, plus the advantage of a second set of experienced eyes seems to me to be an excellent value. It is clear that you do not hold the same view.
Alternate methods of collecting the info may be difficult, but the internet is a good place to start. For each component in question, have a good look at the make/model/S/N, then web search for the owner's Manual/Exploded diagram. You will find many of them online. Others might be found on ebay or craigslist or the equivalent.
Rudder pass-thru: Picture the "standard view" of a boats aft bottom; you will see the inboard's shaft angling down to the prop, followed by the rudder. If you wish to remove the shaft by sliding it out to the aft, your would remove the prop, then slid the shaft down and back... and hit the rudder.
SO, many rudders shafts are placed slightly off centerline, and a hole is placed in the "rudder panel" in such a way that you can remove the prop shaft by turning the rudder hard to one side, and then sliding the prop shaft out, passing it through the hole. This way, you need not disassemble the rudder and all it's equipment to remove the prop shaft.
This "off center" alignment is also one of the reasons that many vessels turn more easily to one direction when compared to the other direction ( another reason related to prop rotation )
RE; bottom paint
If you already have an ablative type paint, then it is highly likely that you can clean then just apply another coat of ablative. But in all other cases ( to my knowledge ) it would be best to strip, then follow the coating mfgr's recommendations.
Props: Talk to your prop shop. It is possible that they have reference material that will tell what "came with the boat". If not, they will be able to give you a "starting point" and a good shop will allow a few substitutions allowing you to get it right.
re: Krylon
I -might- use it to pain an old lawnmower. What you choose is up to you, but even a cheap house brand marine paint should exceed the performance of a non-marine paint. Up to you. If you don't really care, go to the hardware store and see if you can get some improperly color matched enamel paint. It will last for a while...
More rudder:
There is little point in worrying about the rudder shaft if you don't have the details on the rudder itself, but you can likely guess what the rudder shaft size was by examining the the rudder stuffing box. Depends on how and what was removed...
Shane-those Chryslers are good motors but they have been sitting for a long time which is not good. I would at the very least pull the plugs, see if the engines will turn and then take a look with a borescope. Pull the thermostat housing and see what things look like.
Your OP said "I have the opportunity to purchase this boat for $2k as it sits, or with freshly rebuilt starters, and (replacement) rudders and shafts, and props for $3.5k."
Where are the rudders and shafts coming from? If they are from the guy the marina owner sold them to because another deal fell through, It is well worth the $1500 plus, you would be getting the proper material.
My marina just hauled a metal hull house boat. It looked good, however, the metal was thin as aluminum foil in spots and had numerous pinhole leaks. Crawl in the hull and see if there is any surface corrosion that looks like it came from the outside in. A bore scope would be handy here as well.
#14: Barrier coat? Why would you need a barrier coat on an alluninum hull?
