I pressure tested the outdrive after changing the carrier bearing and it's leaking from 16# down to zero at about 1/10th of a pound pressure every 15 seconds. It's about 30 minutes for psi to zero out. I sprayed soapy water all around the assembled outdrive but I'm not finding air bubbles. How much of a concern is this rate of leaking?
