Jeff
Working backwards,
Docking- as long as the slip is sized properly I’ve had no issues. Just to be clear with my first slip I got in & out of it with no problem- but it was May and there were very few boats in other slips. After the marina filled up I didn’t have enough length in front of me to get into the slip without major help. No problems with other slips and my new slip is a dream. More then happy to give details
Now, I had my 50’ Cruisers for over 10 years and could thread a needle with it, yet under the same circumstances it would have been a no go also.
Also as I like to run the boat from the lower helm so I’ve taken most of the canvas off the bridge which I’m sure cuts down on some windage issues. I have covers for all the bridge seating as well as for the helm. Also have a boot for the Bimini when I fold it up.
Im still not 100% comfortable with using the rearview Cam when docking so depending on the slip I’ll dock from the bridge.
So as of now I’m not single handling the boat like I did my Cruisers but expect to next year
Access to filters, pumps, impellers, batteries, etc.:
So far access seems very good for most maintenance items outside of the engine stuff. Very many access ports to get to things and all items seem to be of high quality.
As the 530 came with 4 maybe 5 engine options, I can only speak to the Volvo 12 liter engines, which I’m guessing would be the worse of the bunch.
Presently I’m 6’1”/ 240lbs & although I work out 4-5 days a week 6+ decades have taken its toll on me and im not as limber as I think I am. That being said most of the engine access is very good.
Being straight drives the rear of the engines as well as tops, bottoms and inboard sides are very easy to get to as you can walk in between the mains to the front bulkhead where the 4 thruster batteries are. Each engine has 2 8D-starting Batteries behind them and then 400gal fuel tanks & Racors. Behind the tanks there is about 4/5 ft of space with the ER ladder & then the Gen, Gen battery as well as 2 8d house batteries/inverter-charger -rudders etc
The filters, dip sticks have been mounted inboard so no issues. The starboard impeller maybe a bear as it’s on the outside of the engine and I haven’t been there yet. Ill see in the spring or just have the yard do it. Port impeller no issue. The front of the engines look tight & changing belts don’t look like fun. The port engine has 2 alternators and I cant see ether, but as I get the know the boat better it may not be an issue.
Again this is with the largest displacement engines the 530 came with.
The 530 seems downright huge compared to my 50’ Cruisers. So far Ive had a max of 15 people on the boat and can easily see 20+ people being comfortable, Yet I cant imagine having more than the 15. Its like herding cats. The master SR is crazy big. Has way more closet/storage space than the Cruisers.
Also major headroom throughout
I think I touched on how it runs in another post. Email or call with any questions you have
A
