Vic,
My boat is a 1995, the toilet is a Raritan Atlantes, model number shows A12 on the back. It is a saltwater flush with a remote pump. A couple of weeks ago a problem started where if you flush with the normal cycle water would continue filling the bowl and it would never stop pumping saltwater and discharge the bowl. If we then pulled the lever for a dry flush the intake water would stop and the bowl would drain. This workaround was fine until this morning.
Then this morning a new problem started where nothing happens. Regular flush or dry flush doesn't work. I looked at the back of the toilet and no obvious issues with broken or disconnected wires and the wiring and connections still look clean. I haven't checked the head circuit breaker yet, but given the problem started as something else I'm tending to think it's not related to power coming in. I'll verify this tomorrow. Any suggestions on what to check and what the problem could be?
