Originally posted by mixman
Originally posted by Billylll
Since my PuraSan only uses freshwater and was modified to a H-N-T system I would think this would be a huge improvement. I like the was the current system works however it can create quite a mess if the dispenser, the 3 one way valves and the hoses aren't routinely cleaned or replaced. I have always had minor issues with either too little water in the dispenser or too much water.
This new version seems like it would eliminate my issues.
I originally installed my HNT system with an Electro Scan. But switched to the Purasan once it was compatible. I too get those clogs, Bill. Usually during the off-season when the boat is used less. I end up with ruined treatment cartridge that probably had 30 or so percent left in it. The water fill sure is touchy. It gives different levels depending, of course, on the pressure available. I usually set mine to be a bit high as I never get through a full cartridge anyway.
