Sinking boat
Originally posted by Tanqueray
ESTIMATOR....
My point is that sometime in the future he may need parts or something for that engine and it'll be hard to find parts for it unless he knows what he's got.
Nice link you have there for the GM engines but I'll bet ya that being a 1987 vintage that he doesn't have a Vortec Engine. Therefore.......he doesn't have a 305 with 250hp. The 305 4bbls. used back then were rated at 230hp. and the 350's are rated at 260hp. THAT's my point.
Much better and thanks. I now know what you were getting at.....but who's gonna split hairs over 20hp…the block is what it is...entilzah seems knowledgeable also. let’s work together and help him…I want to go fishng on his boat….he is on one of the best striper fishing lakes in the country and is about 100 miles from me........hint hint
Stan
Yeah it was pretty bad, we were out in the leaky boat that day got to see them start the race.
entilzah......The following should end my part of this discussion but now something else has been bothering me.
You claim to be an ASE Certified Mechanic? Well if that were true then you'd without a doubt know whether it's a GM 305 or a Ford 302 because they have two VERY distinctively different Valve Covers and you wouldn't need to rely on a sticker that might be on a Valve Cover.........Not to mention that I'm pretty sure that the Valve Covers off a 305 WILL interchange with the same vintage 350. In fact.....ALOT of the parts from a 305 and the 350's are interchangeble.
Also if you were a Cerified Mechanic you'd also know that visually from the outside the Car and Marine Engines be it a 305......a 350.......a 454 a4.3....or whatever the case may be will LOOK alike whether they're in a car or a boat. The differences are internal in Marine Engines except for the obvious differences in Cooling Systems etc. The Engine is the engine regardless of what it's put into.
Van Parys
RO# 6
Posted - Feb 23 2007 : 16:00:03
I just got off the phone with Dean who is VP at Seloc who confirmed what I already knew which is that it is a misprint, its 230 hp If any one has a real good connection, they can check all the specks for that period here:
http://www-alt.mercurymarine.com/mnetdata/Service/Cruiser/Servmanl/09/cover.pdf
WARNING: its close to a 500 Meg file that you cannot just do a partial load on, so unless your running a serious conection, do not try it.
George Van Parys, http://www.boatfix.com
Homeport: Fortescue, New Jersey
Van Parys
RO# 6
Dahhh, OK dude....but I can tell the difference between my previous 4.3 and my 454...does that mean I'm as gifted as you? As usual...what's your point?
The best thing to have, in my opinion, is the OMC shop manual, the operator's manual the parts manual. Then you have your year and model specific information. The OMC manuals are very good, and if you find an ex OMC dealer selling Johnson/Evinrude, you may be able to order them, they are out there.
And as was said, the difference between a Ford 302 and Chevy 305 is pretty obvious to those who worked on the car versions, one has the distributor in front (FoMoCo) and one in the rear (Chev). In fact, a few years back a neighbor picked up an old 70s Sea Ray with a Merc drive, and he was suprised when I pointed out to him the motor was in fact a Ford, I said, well, have you ever seen a SBC with a dist in the front??
LouC,
Your right, of coarse...it would be great if he has them
Thanks George.
I have a nephew with a "new to him" boat with an engine issue....I'll be back [^]
What's YOURS? Looks to me like you're looking for an argument.
My POINT is..........call a Marina and ask them if they have an eg; Oil Pan for a 1987 OMC 305....
I guarantee you their response will be....
'Is it a 210 or 230'...( not that it'll make any difference. )
Now they're gonna try to determine what engine you have. They'll ask ya if it's a 230 or a 260....You tell em it's a 250. NOW they're gonna assume that you've got a 350. I don't think THOSE would be different either but there's a chance they might be. Maybe an Oil Pan is a bad example......Try a Fuel Pump or a Carburetor.
Just try calling a Marine Supply Outlet and tell them what you think you've got and see how you make out.
Now they're gonna try to determine what engine you have. They'll ask ya if it's a 230 or a 260....You tell em it's a 250. NOW they're gonna assume that you've got a 350. I don't think THOSE would be different either but there's a chance they might be. Maybe an Oil Pan is a bad example......Try a Fuel Pump or a Carburetor.[/size=2][/b] Just try calling a Marine Supply Outlet and tell them what you think you've got and see how you make out.
Tanq...that is exactly what he should do...your first helpful comments and advice to date
Argument?...your still pissing and moaning over 20hp after George verified-it's a misprint. YOU (Geese, aren’t the cap buttons fun) are arguing with what a man is seeing with his own eyes in Texas and you are from ? (FILL OUT YOUR PROFILE) regarding the 305 block that is MARKED as such…YOUR whole statement above sounds like you are arguing with yourself (A PERSONAL PROBLEM)...let me know when you and yourself get it worked out
...in the meantime entilza, did you get anything pulled off that Transome so you could see where the damage is and what it is?
I have not had a chance to tear it up as yet, and I had no f'n idea that reading info out of a trusted name in repair manuals was going to cause such an uproar around here, plus the fuel pump and carburetor from a 350 will mount on a 305 w/o any problems, also when ordering a carb there are numbers on the carb to get the correct replacement. Please let it go, I get it it is a 230HP motor, my bad, it does not change the fact that it is still a 305cid powerplant.
And just where is it 'Marked as such'...?....I've yet to see an engine block with the cid marked as such.
I('m not by any means professing to be any sort of an authority on these things.
That sum's you up rather nicely
Still a pissing and a moaning.....I'll give you this one...he said it is on the covers...I was wrong...you happy now? You've been beating this dog to death, go ahead and cook it up and have some....it'll probably taste better than your foot...
LMAO......Looks like you're the one that might be happy now. It's okay....The truth will set you free.......
All you did was waste alot of time trying to make yourself right and you didn't prevail so now you wanna make personal attacks?
Must be a shame to have so little to do with your time.
Thanks and I'm pretty much happy most the time
Ahhh, Dude...I am man enough to admit when I am wrong, and that flips your switch..good for you...I have been in contact with entilzah via e-mail trying to help, which this place is all about...and what has been your contribution? Nada...Unless you consider pissing and moaning help...try the other foot, maybe it'll taste better
This isn't personal..It's a fact..You wouldn't last a day in NBR
I wouldn't last a day in NBR ?....What makes you think that?
I'll bet you're in the Insurance Industry of some sort....?....You talk like a true Bean-Counter. Say anything when you really have nothing to say at all. Sure you admitted you were wrong but in the same breath you chose to take a couple of cheap shots. It isn't me that had their foot in their mouth but rather you. By the way...I'd also like to bring to your attention that your constant use of the term 'Dude' only goes to show your true immaturity. Do you hang out on the street corners at night with the rest of your Insurance Buddies?
ROFLMAO...you, in NBR? Come on in and let's get really personal...as to what I do, Dude...how did you know? A psychic as well as the worlds best mechanic...I'll sell you some insurance...I believe you just may need it...did I just hear you cram a fist in there with both them feet..gotta hurt
There ARE some ACCOUNTANTS on this board...I'd suggest you keep your shots AIMED at me...you might just piss THEM off (I'm so glad you showed me how to use the caps) ..they might not play as nice as me...
Entilzah let me know how it goes I just had the same problem, and was quoted 3600 to fix...I may want to try and screw it up for the price...
Estimator, you seem very helpful and thanks for replying back as for Tanq he can fall off the face of the earth for all I care, no need to keep wasting typing time on idiots...Save it for us people that need help....
Posted - Feb 21 2007 : 11:00:37
LOL, I'm glad he found it too.
Reading all the posts on his problem, I was beginning to think this was a Test.
Where he knew the problem and was checking us out to see who could lead him to the problem.
Now it looks like somebody may have torqued the throug bolts too much, crushing the transom.
Then seeing what he'd done, backed off on the through bolts a bit. leaving a gap.
Edited by - Thudpucker on Feb 21 2007 11:02:27
Thudpucker, why would this be done, meaning I had work done on my outdrive bellows and gimbel bearing, could they have done this while replacing them???Posted - Feb 21 2007 : 11:00:37
Yes steve, it's possible they may have had the Gimble housing off in making the Repairs.
Keep in mind that I'm guessing from my Back Room here.
I think if you've just had that area worked on, that you'd take it back to them with the complaint, wouldn't you?
They have the experience to tell you right quick where the leak is, and if you press him for the Details, he'll eventually volunteer that they were the last ones to touch that area. IF that's the case.
(I've seen this happen) If he gets angry and shows other forms of agression, you can almost bet he knows what the problem is and where the fault lies.
That usually means you not going to get any compensation. So sweeten up your attack, and see if he'll divulge the pertinent information so you can go fix it yourself.
Some time ago I had some dealings with old Mercruisers. They do not come apart easily somtimes. Especially if they have been in Salt water or heated up for an extend period of time. Sometimes they require a helluva lot of force to take apart. Heat is one common way to help that out.
That might be contributing to the problem too. A cooked transom! Shudder the thought.
It's just possible the Bolts that hold that Gimble Ring were tightend up too much when pulling the Gimble ring down into alignment. Just about anything imaginable might have happend.
First thing though is to see actually where that leak is!
You may have a cracked Gimble housing. Or it may not be tight enough. That'd be nice eh?
One more thing, this happend to someone on this forum too.
There was a Through bolt in his transom. I think it was a 1/4" bolt and nut.
The Bolt rotted in the middle (Nail sick) and let water in at a pretty good clip.
You may have something like that too. That'd be a real easy fix.
How about the Hose from the water pickup in the Foot, to the Water pump in the block?
When you put the Ears on, do you get water in the boat?
Another thing to follow up on my earlier suggetion Get help in seeing how deep the boat must settle into the water before you start getting water into the boat.
That should help identify how far up the Gimble housing to look for the leak.
But have faith, it's all just parts n' pieces, time and money.
Why dont some of these 'economic opportunities' come my way?
Because there'd be a Divorce in my near future! Thats why.
Thud.
Well I'm not about to fall off the face of the earth but now I'm wondering how long you've had this boat and if this is something that just started recently or is it a new to you boat that had the problem from day one? If this is a problem that started recently you might also want to look at the Y Pipe connections.
I had the ears where the bolts go through rot away on one of my engines just from Salt Water use when it was in Florida and had all the same symptoms you're describing. Because of it's location it can disguise itself as any of the problems mentioned.
