Originally posted by Tanqueray
entilzah......The following should end my part of this discussion but now something else has been bothering me.
You claim to be an ASE Certified Mechanic? Well if that were true then you'd without a doubt know whether it's a GM 305 or a Ford 302 because they have two VERY distinctively different Valve Covers and you wouldn't need to rely on a sticker that might be on a Valve Cover.........Not to mention that I'm pretty sure that the Valve Covers off a 305 WILL interchange with the same vintage 350. In fact.....ALOT of the parts from a 305 and the 350's are interchangeble.
Also if you were a Cerified Mechanic you'd also know that visually from the outside the Car and Marine Engines be it a 305......a 350.......a 454 a4.3....or whatever the case may be will LOOK alike whether they're in a car or a boat. The differences are internal in Marine Engines except for the obvious differences in Cooling Systems etc. The Engine is the engine regardless of what it's put into.
Van Parys
RO# 6
Posted - Feb 23 2007 : 16:00:03
I just got off the phone with Dean who is VP at Seloc who confirmed what I already knew which is that it is a misprint, its 230 hp If any one has a real good connection, they can check all the specks for that period here:
http://www-alt.mercurymarine.com/mnetdata/Service/Cruiser/Servmanl/09/cover.pdf
WARNING: its close to a 500 Meg file that you cannot just do a partial load on, so unless your running a serious conection, do not try it.
George Van Parys,
http://www.boatfix.com
Homeport: Fortescue, New Jersey
