The first picture of the new ones is the bilge area in front of the galley. Like I had said, it has had up to three inches of water in it before mist likely from the inoperative shower sump or since replacing it me forgetting to leave it turned on when running the AC. As dirty as this one is, I imagine the one behind the sump under the port fuel tank and the one forward of this under the master SR closet is as bad.
It helps that I am still in my slip. We have had a very mild winter so far. Only a few overnights in the mid thirties. I would not have had to winterize yet.
I will say my back is pretty sore after two 10+ hour days. And I am not really looking forward to doing the waste lines weekend after next but I look at it this way, colder means less stinky. Once the bilges are cleaned and the waste lines are done I can start laying in the sub floor.
A few other things I am going to do since everything is apart and before I put the floor in;
Mermaid condensators
HDMI cables from multimedia center to both televisions
Finish out the cupboard where the washer was with cedar
Refinish the inside of the window cubby holes
Add water filtration in the bilge under the stairs where it exits the tank and goes to the pump
Make a door and finish out the cupboard where the old held went to use for storage
Remove MSR held, make a door and install in led tele. And put a small safe in the back of that
Then I can finally lay in the new floor. I would,d like to take out the vanity too as it is just a space hog for us and we could use that space better. But I have not decided on that yet.
