- Mar 5, 2001
- 3655
- 1,800
Thanks all, for the birthday wishes.
Davita, I don't need two penises, just one that works a little better..
Originally posted by Vic Willman
David, sounds like the cube ejector motor (part # 102) is on the way out. Before replacing the motor, try reducing the water level just a little (horizontal screw that is spring-loaded, at the upper right corner of the metal mounting plate behind the plastic mold cover). Turn it two full turns in the (minus) direction, and see if that doesn't help things. If not, grab your ankles, the motor will have to be replaced before long (estimate for the motor: $75)
EM2, as Gary mentioned, the most common source for leakage is that they've cross-threaded the garden hose conector on the water solenoid valve. Other possible sources are a cracked plastic internal water line, or the water line that feeds the water up the rear of the cabinet has laid on the side of the compressor, and the heat from the compressor has burnt a hole in it.
Take off the lower grille and watch it, especially toward the end of the ejection cycle, when it calls for water to be fed to the ice mold.
