- Mar 5, 2001
- 3655
- 1,800
Mike, the fingers should be anywhere between 12 o'clock and 2 o'clock, when in the parked position during the cooldown cycle. So it sounds as though everything is OK.
Originally posted by Vic Willman
Paul, the wire arm opens and closes a microswitch inside that turns on and turns off the ejector portion of the machine. Given that it's 20 years old, I'd guess that the microswitch is hanging up and needs to be replaced. The trick is getting access to it. First, turn off the machine. Then remove the cover from the front of the ice mold mechanism inside the machine (put screw driver in slot at bottom of cover, then twist). Next, remove the 3 screws that hold the metal plate with the gear, etc. on it in place. From the top of the metal plate, bend the metal plate outward like a door on a hinge.
You'll see a little bump on the wire shutoff arm that contacts a switch, mounted inside the "black box." That switch is most likely the the cuplrit. It's a standard micro switch, about $5 or $6 at Radio Shack. Note where the wires go before disconnecting them, as the new switch will have a terminal that doesn't get used. The old one may also have this unused terminal, or it may not, depending on the age of the unit. Remove the switch from the black box, and install the new one. If there is a spacer installed behind the switch, be sure to replace it with the new switch. Reconnect the wires.
Now, slowly push the metal plate back into position, note that the "tang" on the end of the wire arm MUST go through a small hole in the metal plate, and the spring attached to it must be tucked inside the black box - the spring simply presses against the side of the inside of the black box. Then turn the machine on and see what happens. It should now work correctly.
