Update on Trawler refit
I can just tell you from my learning curve Tony, and what mistakes not to waste both time and money on. You may still want to consider the inverter but only as a combo unit such as a high current charger/inverter. You definately want one you can have the charge parameters changed so if you upgrade your house bank or leave it as is, it will be optimum. Even though I have Xantrex there are better systems for about the same money that if I had it to do over I would chose instead. I will admit I haven't had any Xantrex issues but other's here on the board I trust and know have.
Woody, I like your game plan! Get used to the boat [I'd anchor out 3 consecutive nights.] And then start deciding what is needed and prioritizing the implementation. And remember, if it ain't broke, don't fix it!!! My vote is against a thruster.......
Originally posted by Woodsong
I haven't decided on the thruster. I think I am going to hold off for now. We signed a lease for a slip through end of March. At that time, we will decide whether to keep her on Lanier or go to the TN River. This past week I was in my traveling mood and was ready to say heck with it all and take it to TN right away and go travel for the winter but reason got the better of me and we will stay the course for now. If I move the boat I'll do it then I think, though so far I didn't have any issues without the thruster the 4 weekends we took her out to get used to her.
Once i get her back in the water I am going to be looking more at systems, what to keep, what to adjust, what to add, etc. The issue is I am pretty much an idiot when it comes to these things so I have a lot to learn! I really need to spend a night or two anchored out on the boat to see how the current battery bank, etc. handles everything and what I need to address to allow us to anchor for at least a day without running low and battery power. I also plan on painting the engine room and hopefully cleaning things up a bit here and there in the engine room. Everything seems pretty well laid out but I know I will be moving the batteries right away for better access to the engine.
I am still toying with the inverter as well. Before I do that though I need to diagnose the electrical set up more. I did not realize this until the day I was taking the boat to the service dock for haul out but it seems that some of the electrical outlets on the boat are already configured on 12V instead of 110 (i.e. seems you can plug in a 110 fixture and it will run off 12V). If this is the case then in theory, could I not just upgrade the battery bank and skip an inverter. This sounds retarded but really- the only thing I want to run when anchored out that is 110 is our margarita machine! Lame I know, but it rocks and we use it a good bit with friends and stuff when rafted up- also makes great smoothies for the kids. I also want at least the kids stateroom TV/DVD to run off 12V so we don't have to run the generator for them to watch the (very) occasional movie. Other than that, only 110V items we use are the HVAC and stove (assuming I swap out the old gas stove to an electric cooktop which I am seriously considering doing though that may be a mistake).
So other than me finally getting the CQR anchor this week, the fiberglass guy getting the bridge fully dried in yesterday (all new coring installed and glassed in) (lost a day to rain), and now my having found the leaks on the dingy today, it was a quiet week on my end.
P.S. Bill, i will let you in on my dream. You dream up the systems, I'll pay, you install! ;) If you insist, i'll even let you pay! :D
Tony, did I read your post correctly, I quote,
If I read it right you said you plugged in a 110v appliance into a receptacle and it worked when you were taking it to the service dock.
If thats the case it had to be running off an inverter.
Dvan,
You read correct. I do not have an inverter, however, it seems "somehow" that I do indeed have 110V style recepticals that run off 12V. There is even a switch on the 12V panel that says "12V outlets." I need to test this though via plugging in a lamp or something in the different outlets and confirm! Strange, yes, but it would be awesome.
And todays update:
foredeck glass work is getting near done. All the glass is in and they put down the first 2 coats of new gelcoat down. As well, the new synthetic coring on the bridge has been put down, along with a bunch of layers of glass, and while I forgot to take a picture of it before I left, they got down one coat of gelcoat up there as well today. They also removed and glassed in the old fill cap fitting for the original freshwater tank. That tank was abandoned some years ago and for some bizarre reason or another they installed a new fill cap not 2 feet from the old one but left the old one in place. Why they didn't just use the old one is beyond me b/c access to it would have been very easy but oh well. Hull has been 75% compounded/waxed and prep for painting topsides is ongoing throughout this week.
As well, got the shaft reset from where it had walked back about an inch or so just before haul out,I bought a "new" gas tank and fuel line for the dingy (old one stolen off our dock just before haul out!!), as well as ordering a new bow roller to fit the CQR that I just bought off craigslist, not to mention ordering a new swim ladder since old one only went into water about 6 inches, and a mounting bracket to mount the dingy motor on the trunk deck! :)
Lastly, I met the only certified marine electrician to be had in the area at the boat...getting a firmer price on correcting the boat's grounding system which was not done correctly, as well as some other electrical work, which includes wiring for a new 3 burner cooktop and circuit to move microwave under the cooktop. Yes...we've decided to scrap the old gas stove out of safety concerns with it's age and will be going with a 3 burner electric cooktop when we do the granite countertops once the boat is back in the water. I think it will look good, meet our needs, be safer, as well as allow us to move the microwave under the cooktop which will free up the area over the full size fridge for storage, etc. I can't wait to get the granite tops in!!!
Pics:
Looking good can't wait to see the finished product pictures. Looks like your almost there.
Tony my slip neighbor with the 36 Marine Trader has the same 12 volt outlets and breaker you describe. It is not an inverter circuit. Some low wattage 110 filament light bulbs will light off of 12 volts DC. I doubt anything with a motor or transformer will run as in your blender or an appliance like a TV. I'm glad your having a Pro look and modify the wiring. Make sure of one thing he uses marine grade wire and it is stranded. For all new DC circuits make sure he uses red/yellow color coding. The yellow is now the standard for DC negative too many do it yourself types were mixing black (hot) from the AC circuits with black (negative) from the DC circuits. This is a serious accident waiting to happen. This is why moving forward I would insist on the electrician following today's standards not when the boat was built. I would also suggest when ever possible going one size larger with any new wires run in the boat especially DC circuits. You never know if you are going to add a device or outlet then at least you know your new (feed) wiring can handle the current without voltage drop.
The boat repairs look great.
Next suggestion start ordering and picking out your LED fixtures to replace ever old bulb/fixture in the boat. They have recently come out with dual color LED's for everything from chart table lights to floor walkway lighting. Making the switch to all LED lighting will allow you more DC reserve amp hours while the boat remains bright without having to increase the house battery bank size.
I would even seriously consider replacing the navigation lights to LED. My LED Nav lights are so much brighter I feel it's worth it for the safety of everyone's crew. Again the big added plus is the anchor light is much brighter and will only draw 20% to 25% of the older light's current that probably came with the boat.
Bill, I am going to test the 12V outlets to see what they will power...radio, TV, or margarita machine! :)
The electrician I am using is a master electrician for land stuff but also a certified marine electrician and does inspections for charter vessels for current marine code compliance (wrong phraseology on my part i know but you get the idea!). He definitely seems to know his stuff and all components will be marine grade, including all fittings and all wiring, etc. He spent a long time today going through the boat with me looking at everything and making our list.
LED lights- EXPENSIVE!! Man- the nav lights are like $120 each, times 4 that is a LOT (red, green, anchor, and stern). I thought about them til I saw the price. I definitely want to swap out the salon lights though- really don't like the current lights. I really want to do some small puck lights around the salon but also really have been toying with getting one of these: http://www.weems-plath.com/products/dhr-main-cabin-lamp/
I really want lights that either will be out of sight, out of mind, or nice and classic looking. The LED's would be great but man, I could spend $1,000 just on light fixtures! In light (no pun intended) of how much $$ I am spending on everything else, I can't decide if the cost of LED's is worth it given our foreseeable use of the boat.
That being said, I am 110% open to any ideas for affordable LED's and any links or insight on pricing would be very welcome. I want to do things right but have to weigh the costs, etc.
I bought top of the line my total LED nav light cost was almost $2500.00
I want to install it once and be done, seen, draw less current and light up every crack in the boat!
But that's just me. They have gotten less expensive since I did my vessel. They have also gotten better.
They are worth every dollar Tony. But again that's my opinion. You will also have -0- maintenance issues not to mention the obvious advantage of being seen.
$2,500...hmmm....$3 a gallon for diesel, +/-, generator burning maybe 1 GPH (a fairly new northern lights/lugger with only 276 hours) , that is roughly 833 hours of generator run time, let's call it 800, +/-, hours of generator run time to charge the batteries up due to traditional lights. I should only have to crank the generator, at worse case, an hour per day to keep everything fully charged for a 24 hour period anchored out away from shore power. That means I could anchor out, conceivably, for 800 days, +/-, for the cost of the nav light package? :) Cost/benefit analysis (I know, I know, no point in doing a cost/benefit analysis on a BOAT since they make no financial sense!!) is telling me that it's cheaper to stay with regular nav lights, though I hear you on the visibility issue.
However, I REALLY appreciate input and ideas and suggestions on what to do to the boat during our refit! Part of why I am posting this stuff is just for that reason- to get the insight of others and ideas that I maybe would not have thought of.
Tony I was lucky to some extent when I built my boat. The economy was booming and I figured I wanted to do it right and once. That didn't always work out and I found that the cheapo LED's crapped out early on. I really like my cockpit arch lights the are brighter than the old Halogens and draw 2.5 amps instead of 20 amps. Most of my LED lighting is Lumatec but the nav lights were and still are top of the line I just forget the name. Once I get on the boat tomorrow I'll send you a PM about LED's. You can look at LEDs this way they will allow you to have a smaller less expensive House bank and remain on the hook longer and not neeed flashlights for reading. I like a well lit salon and galley. How you going to show off the granite without accent lighting?
Well, she is coming along! Plan now is to splash her this Friday afternoon right after lunch!! I'll still have work to do on her but the big painful stuff will be done. Pics from yesterday:
Laying out nonskid:
Old windlass teak pad visibile in foreground. Replacing with 3/4" starboard:
Bridge Deck:
New bottom paint:
JUST ADD WATER:
Also, it should be noted just how committed the boatered community is to making sure everyone is taken care of. Just so that our little trawler would not feel lonely in the yard, member Coolbreeze767 hauled his houseboat out and parked her right next to us in the yard! You can see her in the last picture. Rick tried to pretend it was due to his needing some work done on an outdrive but I know he really just wanted to make sure our trawler didn't feel lonely.
Looking good.
Is standing practice in your boatyard for dry docked boats to leave their fenders out?
Originally posted by In the know
...Is standing practice in your boatyard for dry docked boats to leave their fenders out?
Looks great.
Seeing the houseboat, it appears to be so. At first I thought Wood was indicating the boat was a male.
Looking good.
I left the fenders out in case someone wanted to raft up in the yard!!! :)
truth be told, they're out so as to keep them out of the way when walking around the decks, etc. as the work is being done.
I figured as much. It was more sarcasm than anything - it just seemd funny in the last pic to see two boats on the hard and both with fenders out.
Tony looks like it's time to start with the comfort features. You want to make it like your home and office. This will allow you to spend more time on the water than either home or at the office. It has really worked well for us this year on average we spend on average 5 out of 7 days a week on the boat. I would not be able to do this if I didn't have a VPN for data in to the office and Sat TV for our enjoyment. Those are the minimums for my wife and I.
Bill,
historically, with our silverton the 3 years we owned it, we spent about 120 nights a year aboard...lots of 3 day weekends, etc. So far we have been happy with just cell phone access and our USB internet connection card for the laptop..not as fast as DSL but it works for what I need it for. Most of the data I work with I upload to the web via my DSL at the office so I am usually either just emailing out links to the various stuff for boats or real estate, as well as emailing contracts, etc. Simple, but it seems to work for us thus far.
On the TV....we are pondering what to do. I am having a hard time deciding that a full tracking system is worth the $5k. We are leaning towards getting the Track-It-TV set up. A guy on our old dock got his boat repossessed earlier this spring- he stripped off the sat. TV system he had....could have bought that cheap and maybe should have but felt weird about it so I passed.
So yes- let's talk Sat TV systems.......we're not big TV watchers but we are seriously thinking of taking the boat up to the TN River this spring and doing some longer cruising so I want it to be comfortable and feel like home. We've already got the flatscreen in the master stateroom and I have one that can be mounted outside up rb2@gr5t the bridge if we want (client gave me one this year) and we want to put one either in the salon or in the kid's stateroom. Our silverton was set up so that the kids stateroom TV and their DVD player would run off 12V which was great- definitely want that set up again.
Suggestions for actual TV's and 12V ones at that are appreciated. I think we are going to go with some type of flip down screen mount for the salon so that it can be mounted from the ceiling over the fridge.
