Update on Trawler refit
5k sounds a bit high I have been looking as well I plan on spending more like 2K.
All looking good Tony. Congrats on the improvements and thanks for sharing.
PaulS
You won't go wrong with either the KVH M1 or M3. I have the M3 Tony. Once you start rural cruising your USB modem will not cut it especially on the Ten Tom. I suggest looking at an Ericsson W35 and an external antenna on AT&T. This gives you a phone line, UMTS 3G or 2G if thats all that is available, a 4 port LAN switch and a small WiFi access point so you can share the connection on the boat. Again your cellphone in the boat will not have the coverage or ability to grab signals from distant towers like the Ericsson W35 and an external cellular marine antenna. The W-35 runs on any voltage from 10.5 volts to 28 volts DC. I prefer Digital antennas for all my VHF and Cellular modems. With the W35 (they can be purchased for less than $595.00) you can hook up a cordless phone and use it anywhere on or near the boat. Here is the plus about the W35 if you already have a AT&T SIM card just remove it while on the boat and install it in the W35's SIM port. Google Ericsson W35 it is one really cool unit made for boats, RV's and remote homes. Also check EBay from time to time I have seen used KVH M3's for sale. I would also recommend a Wave ROGUE WiFi unit you would be surprised what you can pick up even in the middle of nowhere. As far as the Flatscreen I recommend the 12 volt units made by Jensen they cost a few more bucks but they have conformal coated boards and again made for RV's, trucks and boats. Why run an inverter when all the above devices will run on a standard 12 volt system. I'll say it again always think of everything being a system. I decided early on most of my systems in the boat were going to be 12 volt DC based so I didn't need an inverter or generator failure to ruin my time on the boat. Which leads me to alternative charging of the house battery bank, I highly recommend solar. I have a 3 panel system that puts out 440 watts at 24 volts that is controlled by a Morningstar controller that drops the voltage for a 12 volt battery system and is a 3 stage charger. I see at least 15 amps for 5 to 6 hours a day or almost 100 amp hours a day of recharge just off the solar. It's more than enough to keep my dual voltage NorCold frig running if I lose dock power and has enough spare current to keep the house bank charged.
As you can see I'm talking system and basing the important stuff off of 12VDC.
By the way for low current efficient 12VDC fans I recommend Caframo units the one's I use have an automatic shut down timer you can set for 2,4,6 or 8 hours and they have 3 speeds.
I'm just trying to give you some ideas.
Your first photo is titled "Laying out nonskid:". What exactly does that entail? I am not at all comfortable with the OEM nonskid on Saint Max. It is not near as aggressive as on my former Regal yet the boats were only a year apart in date of manufacture.
Really good thread... love seeing this classic boat being brought back to 100%. Someday the family would love to own something similar... nice slow cruiser... economic and comfortable. Nice choice of a boat!
Tony
I took the "low-tech" approach to the TV issue on my 391 by installing a Vizio 26" HDTV with the built-in hi-def tuner, a Blu-ray player and a digital antenna. The antenna receives over 20 stations in my area in hi-def ! The reception is crystal clear and there is no monthly cost, just free over the air HDTV. The Blu-Ray player on the Vizio looks great. I have less than $500 in the entire package.
Neal, can you email me the model # on your tv? Is it 12volt?
My HUGE quandary of the day..... I got a call from a marina on TN River that I've been on waiting list for 2 years. They told me they now have a slip available for us!!! It's only about 10-15 minutes extra drive from lake Lanier, yet we could cruise anywhere from there. Dock fees are less too. As well, I can get q much better paint job done up there as I have determined there is basically no one that can do a good job on paint here since no yards allow spraying. Plus, yards there are more accustomed to doing work on my type of boat there. So...what to do. We were supposed to splash back in Lanier tomorrow but I just delayed it to see what we want to do. Also got a quote today from a hauler to take her to Chattanooga and it was affordable and can be hauled next week. We already have several friends up there on the river. What to do, what to do??!! We had told ourselves we'd stay on Lanier til spring then go to the river and take a month cruising this summer with the kids. But now we have a slip on a good dock there.....Hmmmm. What arethe odds that the day before we sash back in the lake we get a call thatcher have a slip for us on the TN River?
Sorry for above typos...on my iPhone!
Kida, we taped off the nonskid areas and used durabak 18 for nonskid- spend entire day out there today doing a bunch of stuff and we put down 2 coats...may do a third tomorrow. Precious owner used same stuff on rest of nonskid or I would have gone for a Belford diamond pattern but pretty much forced to do same as rest of boat. Haven't been able to walk on new stuff but older sections are ok...not the best from a cosmetic perspective but very good doing what it is supposed to do- not letting you slip!
What to do Move it to the new location Tony take it to the river this will broaden your cruising horizons.
+1, sounds like a "no-brainer"
Tony,
If you're thinking Track-It TV (is it "Follow-Me" now?), I believe that system is under $900. I have the AzTrax system (pic below) that's around $1k. I like it because it's easy to stow, and the dish is small and included (Track-It doesn't come with a dish so you have to use a gray one). Both work with either Dish Network or DirecTV. Dave is also right that dome dishes have come down to starting at $2k now. I bought mine about 5 years ago due to price and the fact we never watch TV under way. I'd buy it again as we've been very pleased with it. We've used it from MD to the Bahamas and never had a problem. What you get now for $2k is not having to manually find the bird in the sky. That part doesn't bother me, but it depends on your comfort level with satellite reception.
Of course, reception does suffer when you get this fellow perched on top of the LNB:
Tony 12 volt KVH M1 complete packages can be had on EBay for $2300 new.
Wood: you have listed several very good reasons to move your boat to TN River and the only thing against it is now instead of in the spring? I'd say the decision is obvious. Just go for it!!!!
Tony,
Do a search on '12v travel tv' and you'll find quite a few options, including some with built-in DVD player.
I agree with FB...if the only reason for not moving to the river is the season, I also say go for it!! It'll open up a whole new boating world for you and your family.
Woodsong, are you having fun yet? Getting that trawler back into shape is alot of work. Keeping looking good will take work too. Must be nice to have a boat to have style & character that does not age with every new model year.
I think I am still having fun! :) I was talking to the seller the other day on the phone as I had to ask him a question. He asked how it was going. Really, I looked at several other boats that needed work and pretty much concluded they were not worth the effort at all. For some reason this little trawler calls to me and I really have an affection for it and it's really been a labor of love to get her back into shape. So....still having fun. Still more work to do, but still having fun. No surprises thus far which is nice. I should know this week what we are going to do about the river. I tentatively had set up a slip on Lanier for when I was done with the yard work. If I can gracefully extract myself from that scenario we are going to the river, for the primary reason I can get some of the work I want done up there better and easier as they are more accostomed to working on boats like our Monk. Stay tuned!
P.S. This week not much work getting done...fiberglass work all done, ready to splash, but holding off trying to see where i am going. I have been taking advantage of the time to do more research on whether to swap out the old propane stove for an electric cooktop or get a new propane stove and replumb the entire propane system. Anyone here ever redone a full propane system???? The "marine" propane ranges cost $1,200- $1,400 which is insane! I've heard from quite a few trawler owners that they have used the propane stoves that you can buy for RV's which cost only about $300-400...main difference seaming to only be stainless steel vs. black metal. The regulators, seloniods, sniffers, and service lines seem to run around $500 so I think I could plumb the entire system and get a new range for $800-$1,000. I had all but decided to just go with an electric cooktop set into the new granite countertops but other trawler owners are encouraging a traditional propane set up. So...I don't think we have a lot of LRC type boats on boatered or sailboaters, both of which typically always use propane, but would love to hear if anyone here has much experience with propane system set up.
Tony, the boat is looking good. You're welcome to come join us on the TN. As you know, the cruise up to Knoxville is beautiful and there are many quiet coves to hang out in. Fall leaf watching is great from the water. And there are still 3 home football games - being part of the "Vol Navy" is a unique experience. We'll look for you in the spring if not earlier.
