Help!!!
I recently replaced the vacum tank on one of my vacuflush systems (model 506) because one of the hose fittings became brittle from old age and snapped off. Since I replaced the tank, the system is leaking, i.e. pump is cycling every 5 to 10 minutes. There was no leak before I replaced the tank. My vacum tester shows that the system is holding vacum all the way to the hose fitting on the back of the tank. The toilet bowl is not losing water, yet the system is losing vacuum. What is next that I should check for? Would the funnel assembly on the bottom of the toilet be the likely culprit? Need help please.
